Old 06-14-2014, 03:38 PM
another1 another1 is offline
330d Cabrio
Mein Auto: 2007 330D SE Cab
Slipping Gearbox.
Hi Folks,
Apologies first off if I am duplicating content. In which case I would love to get a thread link.
I have a problem.
The gearbox on my 330D is slipping. The slipping occurs in the first 3 gears I think.
Its due to go into BMW to see what the problem is.
Having read around a bit about this it appears that the transmission fluid could do with a change ? Its done 97,000 miles and this problem has manifest in the last week. Suddenly.
I have been at traffic lights and gone to pull off only to see the rev counter rise with no power.
To make matters even worse I think I have noticed a leak under the car.
BMW cant take the car for 2 weeks and I wondered if I should drive the thing at all in that time. Is BMW gonna quote 'no transmission change necessary' at me as I have read in some forums ?
Has anyone got any advice for a newbie ?
Thanks in advance...
Old 06-14-2014, 06:10 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by another1 View Post
Hi Folks,
I have a problem.
BMW's LIFETIME transmission fluid now quitely changed to 100k mi. Most consider that a maximum, with no penalty to changing earlier.
Also, cure that leak! Sounds like your fluid's low.
Old 06-15-2014, 12:14 PM
avocet avocet is offline
Mein Auto: '07 328i
If your trans is slipping due to low fluid, STOP DRIVING IT. The two worst things for an automatic are heat and low fluid.
Old 06-15-2014, 05:03 PM
330d Cabrio
Thank you for the warning. I will definitely heed it.
Old 06-15-2014, 05:04 PM
330d Cabrio
Thank you.
Wonder why its now leaking though. I'm fairly sure it is leaking.
Old 06-16-2014, 06:47 AM
330d Cabrio
Just got off phone to BMW.
A transmission flush in their eyes requires 10litres / liters of oil.
There has been no mention of the filter, though I will likely push to have a conversation about that at the time.
Cost of this in the uk is around 500gbp. Not cheap.
gear slipping, transmission, transmission fluid change, transmission slipping
