Old 06-14-2014, 05:06 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
Can the Slip ring be reset? (no wheels controls)
So I replaced my lower steering column and I never touched the upper part of the column took it all apart from the firewall side and when I had the wheel apart I remember my son spinning my wheel which wasn't an issue un till i assembled my car. now the wheel buttons and shiftier paddles do not work. can the slip ring be reset or do i need to buy a new one?
If you like customer service. Don't look beyond a BMW.
Old 06-15-2014, 05:54 AM
Mein Auto: '06 AW 330xi
I would try coding the szl first before replacing. Just default it with expert mode in ncs.
