Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 06-15-2014, 05:39 AM
michiuk michiuk is offline
Mein Auto: BMW 530D GT
spark plugs
Hi all, how often should spark plugs be changed on m3 the car is coming up to 60.000mls and service history doesn't show spark plug changes i know they should be changed at inspection 2 service but there are no invoices to show this.
Old 06-15-2014, 06:26 AM
NASA43's Avatar
NASA43 NASA43 is offline
Make Their Ass Quit!
Mein Auto: 2008 M3
Should be changed every 30-37k. Mine were changed by the dealer at 30k.
2008 M3 Sedan, Silverstone II, Fox Red Extended, 6MT
Old 06-17-2014, 09:52 PM
sparkshaneman sparkshaneman is offline
Mein Auto: 2006 650ci
spark plugs
I have a 2008 M3 w/18k miles. I took my car in for an oil change and was told that I needed new spark plugs ($400). I questioned the spark plug change and was told it's CBS and I needed new spark plugs. 2008 w/ONLY 18k miles was my response and was told it's based on how often the car is started, which negates the 18k miles on the odometer. Thoughts? I feel like this service isn't justified.
Old 06-18-2014, 05:17 AM
NASA43's Avatar
Mein Auto: 2008 M3
I'm looking at the 2008 Service Manual and it says "Spark plug service (not shown in CBS): replace at 37000 miles." $400 seems awfully low for an M3 spark plug change. I thought it was more in the $800 range.
Old 06-18-2014, 07:42 AM
I get employee rate on parts and labor, which is why the pricing is lower. The SA wasn't happy when I questioned/refused the spark plug work. I still dont see any reason why I should have this serivce performed, unless I'm missing something.
Old 06-19-2014, 07:47 AM
bimmertech113 bimmertech113 is offline
Account Under Review
Mein Auto: a car
It's a preventative maintenance. Replace them before it starts to misfire. I'm in the Nashville area if anyone needs a BMW master tech for anything.
Old 07-08-2014, 07:51 PM
DaStig DaStig is offline
Mein Auto: E92 M3 Jerez Black
There is a tool available on Amazon that enable you to do the plug change yourself. Beats paying $800 at the dealer and prevents breaking the coils trying to get them out:
http://www.amazon.com/s/ref=nb_sb_no...s=division%20m
Old 07-25-2014, 04:46 PM
rolfjahn rolfjahn is offline
Mein Auto: M3/335/911 G50s/911 Turbo
Replace at 60K
Old 08-29-2014, 06:09 AM
TeaRex714's Avatar
TeaRex714 TeaRex714 is offline
Mein Auto: 2015 740Li
I've replaced mine twice. Once at 100K and once at 200K (miles), and they weren't in terrible shape either time. $400 for a spark plug change is insane, $800 is just plain unethical. Only two of them are even a little bit hard (both rears, with the passenger side rear being the worst), and that's only because there isn't much clearance. Just make sure you have at least two short extensions for your ratchet and you'll be fine. No room for one long extension.
2015 740Li Black Sapphire Metallic. Her name is Samantha
2008 M3 Sedan Alpine White / Fox Red - Sold at 219K miles
Old 08-30-2014, 10:25 AM
ablairsmith ablairsmith is offline
Mein Auto: BMW 2009 328i e93
I replaced mine this morning in just over an hour. $60 for the plugs. And I'm a girl (also, I didn't need the special socket that I've seen all over the board--the 12 point one?)
