Old 06-19-2014, 10:56 AM
Henry321 Henry321 is offline
Mein Auto: Scion TC
335xi what does it cost when stuff breaks?
I already have seen the schedule maintenance cost that does not seem too bad at all. My bigger concern is what does it realistically cost when parts break major and minor? If anyone would like to share from there first hand experiences that would be greatly appreciated.
FYI I would be going through independent shops not the dealer and would definitely shop around for best price.
Also is the 335xi pretty durable. I tend to beat on cars pretty bad and also would like to be able to take the car to the track on occasions. Had to rebuild the transmission on my Scion TC. Have needed lots of new parts in past, etc.
Getting a car with warranty is out of question as I will be putting on aftermarket exhaust and stage 1 or 2 tune.
Old 06-19-2014, 12:41 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Total expenditures, excluding gasoline, through 116707 miles:
Repairs (miles, item, cost) [$2356.01]
547, LPFP line disconnect, $0 (BMW warranty)
3063, Headlight alignment, $0 (BMW warranty)
19437, HPFP replacement, $0 (BMW warranty)
43949, HPFP recall - ECU reprogram - seat belt extender - brake light socket, $0 (BMW warranty)
76311, Collision damage repair - active restraint reset - alignment - inspection, $0 (other driver's insurance)
93251, Battery cable, $0 (BMW recall)
101614, Repair door ding, $140.00
116669, Front brakes, 2 Continental DWS tires (tire insurance), water pump, thermostat, alignment, cabin air filter, engine air filter, $2216.01
Maintenance (miles, item, cost) [~$5312.00]
2812, Oil and filter, $57.83
9428, Oil and filter, $82.30
18364, Oil and filter, $0 (BMW maintenance)
27056, Oil and filter, $76.82
36993, Oil and filter, $0 (BMW maintenance)
43321, Oil and filter, $81.01
45676, 1 qt oil, $0 (BMW maintenance)
51805, Oil and filter, $66.15
59858, Oil and filter - microfilter - 60k check, $89.97
67811, Oil and filter, $62.87
75111, Oil and filter, $74.38
82646, Oil and filter, ~$75.00
89909, Oil and filter, ~$75.00
97403, Oil and filter, $73.95
105340, Oil and filter, $74.41
110673, Serpentine belt, tensioner, pulleys, $505.56
112901, Oil and filter, ~$75.00
14031, Mount winter tires, $21.70
19949, Alignment, $75.00
21397, Mount A/S tires, $21.70
39428, Mount/balance tire on replacement rim, mount winter tires, $48.88
46257, Mount A/S tires, $21.70
66026, Mount winter tires, $21.70
75579, Mount and balance new A/S tires, $xxx (looking for receipt, around $100)
85577, Mount and balance winter tires, $80.00
91933, Mount A/S tires, $24.00
97709, Rotate and balance tires, $59.67
106420, Mount snow tires, $21.70
113083, Mount A/S tires, $21.70
28183, 30k check - F/R differential fluids - Transfer case fluid, $xxx (looking for receipt, around $380)
43949, Microfilter - brake fluid, $0 (BMW maintenance)
48557, Spark plugs - rear plate holder, $0 (BMW maintenance)
59945, F/R differential fluids - Transfer case fluid, $375.06
60616, ATF fluid change, $490.50
60820, PS fluid change - air filter, $80.34
76695, Microfilter, $29.40
90685, Spark plugs - ATF/Filter/Pan - Front diff fluid - transfer case fluid - brake fluid - wiper cover, $1092.06
93251, Rear differential fluid - coolant, $329.28
95988, Air filter - micro filter, $53.75
99338, Walnut blast intake valves, $495.00
Consumables (miles, item, cost) [$3668.54]
14031, 4 Blizzak WS winter tires / wheels / TPMS sensors, $1308.83
39428, replacement winter rim, $168.77
75579, 4 Continental DWS tires, $586.13
85577, 4 Blizzak WS winter tires, $681.92
99338, Rear brakes, $632.05 (front brakes @ 116669 miles in repair listing above)
116669, 2 Continental DWS tires, $290.84 (2 others under tire insurance in repair listing above)
That's for the first 117k miles.
All in, figure $11,347 over 5 years and 117000 miles with tires/fluids/brakes. Under $0.10 per mile, which is about 2/3 of what I spend on gasoline. About $2,270 a year all-in, which is a hell of a lot less than the depreciation on a new one.
Old 06-19-2014, 09:06 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Dude! Are you an account or what? That is an impressive list of details! Who could have a problem with their BMW with that attention?
Old 06-19-2014, 10:31 PM
wilt wilt is offline
Mein Auto: 2011 328i
Ignoring routine maintenance and the usual replacements (tires, brakes, belts, hoses, etc), I only spent close to $7000 on parts (discounted via BMW CCA membership) and labor (dealer price breaks on service labor) on my (less complex) E46 in the 40K mile interval from about 95000 to 135000 miles!
Old 06-20-2014, 06:52 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
I was about to about the $7000 for the E46, but then I noticed you paid the dealer. So that was what, one small job?
Seriously though, what the hell did you spend $7,000 on in 40k miles? I owned my E46 for 5 years and 90k miles, and my total, including routine maintenance, was MUCH less than half of $7K.
Old 06-20-2014, 07:19 AM
I owned the car from new...delivery in Munich. So I CARED for the car because I knew I would have it for 10 years or more (actually 13 years!)
600 oil filter gasket
180 winshield washer pump
690 tensioner belt pulley
250 A/C tensioner
270 fuel filter
535 oil level sensor
700 water pump
240 thermostat
480 valve cover gasket
150 alternater idler
760 cyclone separator
700? fuel pump
1000 hoses of various sorts including A/C, power steering
550 coolant expansion tank
I owned an E30 for about the same amount of time, and spent about $4000 during the same interval. The E46, unlike the E30, did not give me respite from expense and that is why I sold it!!!
Old 06-20-2014, 08:52 AM
floydarogers's Avatar
Pedant and Curmudgeon
I can match for our '91 525i - Zooks and I are obviously a bit OCD...
Date Mileage Problem Cost My labor
Sep-96 52,447 Brake Light Switch recall $-
Sep-96 52,447 Airbag ring recall $-
Oct-00 99,699 Radiator cap recall $-
Oct-00 99,699 Blowing Fuse $100.15
Jan-92 1,200 1200 Mile service $37.92
May-92 18,000 Inspection I $285.81
Sep-92 22,800 Oil change $24.96
Sep-92 22,800 Minor warranty stuff $-
Dec-92 24,717 Minor warranty stuff $-
Nov-93 36,854 Inspection II $482.27
Nov-93 36,854 Fuel system recall $-
Nov-93 36,854 Electrical/Ignition recall $-
Apr-95 38,906 Engine miss/Check engine $134.71
Jul-95 42,112 DME Recall $-
Jun-97 59,868 Inspection II $499.44
Jun-97 60,086 O2 Sensor, Coolant hoses $305.26
May-98 70,126 Cruise/throttle cable recall $-
May-98 70,126 Oil change $62.93
May-98 70,666 Replace 2 coils $297.40
Jul-99 86,164 Replace 4 coils $489.94
Nov-99 91,032 Inspection II $631.90
Nov-99 91,032 Brake Flush, Belts, Muffler $895.78
Jun-00 96,452 CEL, O2 sensor $395.05
Aug-01 110,016 Inspection I, fuse, Fan clutch, Brake Flush $804.87
Sep-01 111,320 Thermostat $53.88
Dec-01 113,190 Heater core, center muffler $1,553.48
Feb-99 75,000 Coolant Level Sensor $37.03 Yes
Jun-02 119,638 Inspection II, brake flush, valve cover gasket $1,354.30
Mar-03 127,408 Water pump, thermostat, belts $765.22
Oct-03 134,497 Front shocks, ball joints (labor) $443.91
Oct-03 134,497 Front shocks, ball joints (parts) $500.00
Oct-03 134,497 Rear shocks, ball joints (parts) $250.00 Yes
Aug-04 140,904 Inspection I, Tests, speedo sensor, Fuel Sending Unit $598.29
Jun-05 147,693 CEL, O2 sensor $248.86
Dec-05 150,882 Radiator replacement $656.19
Apr-06 160,830 Inspection II $657.49
Aug-07 186,161 Inspection II $762.75
$13,329.79
My 2001 330xi probably cost about the same, but it had one extreme case of a front differential failing - $2500 parts+labor. It also had costs for a front wheel bearing, and costs for front CVJ cover replacements. I traded it in at 145K partly because I was worried that the transfer case was beginning to fail - that would have cost $3500 (I no longer do that heavy stuff) plus I would have spend another $1K for a new clutch to take advantage of the tranny being dropped.
