Old 06-19-2014, 12:04 PM
updownsidewall's Avatar
updownsidewall updownsidewall is offline
Mein Auto: 2007 328i
light failure
When I start car I get exterior light failure. Checked brake lights and all lights, see no failure.
Any suggestions
Old 06-19-2014, 12:06 PM
Mein Auto: '06 AW 330xi
There are 2 bulbs in the brake lights
It's easy to miss. Check again
Old 06-19-2014, 03:32 PM
Thanks I didn't know that, I'll check again Both lights in Trunk lid are out. Buttons are really in tight, is there a tool to remove them? Okay I used pliers and all bulbs are good. Probably a broken wire
in the bundle car to trunk lid. Color code is blue black and green yellow to other light. I had this happen on a MBZ once. I got to get a service manual. Back-up lights work and running lights work but not brake lights.
