Old 06-19-2014, 07:44 PM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
TPM Inactive
Hello all!
I had to replace my angel eyes parking light. I ordered a set on Amazon
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
All went well with the driver's side install. I had to pull the wheel off and the fender liner. There was a cable attached to a sensor on the liner that I did not expect but removed the clip easily enough. I then demoed initially the wrong box with the T15 torx screws. Found the right cover for the parking light bulb and replaced it. placed everything back together well or so i thought. The light worked well and was much whiter / brighter than the OEM which is dull and yellow.
However, once all was put together I received a TPMS Inactive error. I get the error if the lights are on or off. I need to pull everything off again but any ideas on where to look? what sensors are behind the fender cover that are related to TPMS? Thank you!_a_
Old 06-22-2014, 01:01 PM
2008e92335xi 2008e92335xi is offline
Mein Auto: 335xi e92
Hi there. there are rdc transmitters on the inner panel of each fenderliner. It looks like a square box and says "rdc transmitter" on it. I would double check that you reconnected the transmitter to the connector because that can throw the tpms inactive error.
Old 06-22-2014, 04:32 PM
07335's Avatar
Yup that was it. I had to really press the plug in. Lights are great. Much brighter than oem. Thank you.
