Old 06-23-2014, 02:39 PM
Type E46 Type E46 is offline
Mein Auto: 2005 Black E46
Exclamation E90 LCI sedan with halogen headlights - PY24W to PSY24WSV
E90 LCI sedan with halogen headlights - Front turn signal bulb PY24W to PSY24WSV... Has anyone tried it? Does it work? I don't like the led options but want the clear look...
Old 06-30-2014, 09:15 AM
Anyone!?
Old 07-01-2014, 09:08 AM
Mein Auto: '06 AW 330xi
If you have an LCI, your turn signals are LED arrays. You cannot modify these with anything aftermarket without significant modification.
Old 07-01-2014, 09:14 AM
I have halogen headlights not xenon. The halogen headlight turn signals are a single bulb not the cluster of small led's that are found on the xenon headlights.
Old 07-01-2014, 12:55 PM
The LCI headlights, regardless of xenon or halogen, have LED arrays for turn signals.
There are 2 manufactures for the halogen housings, Valeo and ZKW. Unless one set has the LEDs and the other doesn't, you don't have an LCI. You would have a pre-LCI model
Old 07-01-2014, 01:09 PM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
Not true, I have halogen turn signals on my 2011 LCI e90. Only the xenon headlamps have the cool looking LED array.
You can see the orange bulb in my signature picture.
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats
Old 07-01-2014, 04:54 PM
I have the Valeo headlights on my 2011 LCI e90, it has the halogen turn signal bulb just as nerd boss said above. I'm just trying to figure out if the bulbs can be replaced with the chrome style bulbs and not throw a error code. Anyone!? I can't believe no one has tried this yet.
Old 08-24-2014, 02:49 PM
Bump!
Old 08-24-2014, 05:10 PM
Wongway Wongway is offline
Mein Auto: 2011 E90
Those are regular halogen bulbs?
If so, you can replace halogen with halogen without error codes. The only thing different should be the coating on the bulb. And no coating will throw error codes.
Old 08-24-2014, 05:31 PM
It is a halogen bulb wih a halogen bulb so it should work but I'm looking for someone who has actually tried it.
Thanks for the reply wongway!!
