Old 06-23-2014, 04:26 PM
550maranello 550maranello is offline
Mein Auto: Leased VW Jetta
Smile 2007-2008 335i are the injectors and turbos a reason not to buy one?
Hello,
I have been looking to buy a 335i coupe. I saw three 2007 [auto with 50K; 6 speed with 70K and auto with 86K] and one 2008 auto with 80K miles and a bumper to bumper extended warranty including wheels and tires until September 2014. This car is in immaculate condition with every possible option and tasteful cosmetic upgrades.
An indie shop told me to stay away from 335s because of injectors and turbos constant failure. Is that true, even if the car has been meticulously cared for?
Please advise,
Best regards,
Orazio
Old 06-23-2014, 05:19 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by 550maranello View Post
Hello,
Uhhhhhhhhhhhhhhhh.........no.
Mayhap Indy believes BMW can have a best seller with constant injector & turbo failure. Oy!
Old 06-23-2014, 05:59 PM
johntampa johntampa is offline
Mein Auto: 2008 335i
I have a 2008 335 and sure enough I had to replace my fuel injectors (not cheap).
About 60K miles.
Bmw seems to want to do maintenance yearly on fuel injectors.
I always get a salesman, pushing me to do that.
I've probably had $3,000 in repairs in almost a year and half.
So be warned.
Old 06-23-2014, 06:03 PM
And one more thing... I was averaging 19 mpg until I go the fuel injectors replaced.
Now I am closer to 23mpg.
I guess it's better than nothing.
Old 06-24-2014, 07:07 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
The wide spread problems are fixed at this point. Just make sure all warranty work has been done. Also there is a BMW extended warranty on hpfp (2006-2010) and injectors (2006-2008) for (I think) 10 years 100k. I'm not certain on the dates, cross check with any model you might buy. Are there still a few people that have an issue with these parts, yes. However, no more than any other bad part that crops up in modern cars. N4S
Old 06-24-2014, 01:41 PM
tmaster1 tmaster1 is offline
Mein Auto: e90 328i 2008,E93 335I 07
I just acquire a 2007 E93 335I and I asked my SA about the injectors and they are under warranty to 100K miles. No matter the years that have pass by. I have had this SA for a while now. I have been going to this specific dealership for a while. Since I traded my last 5 series and started driving 3 series. from a E36 to a E46 to a E90 and now a E93. So I am hoping that this is the truth. If anybody out there have different information on it please share it with us. Thank You.
Old 06-24-2014, 02:35 PM
misterjim's Avatar
misterjim misterjim is offline
Mein Auto: 08 335i 6MT convertible
I've never heard of an extended warranty based on mileage alone. Usually, it's something like a 100,000 mile/10 year deal. I hope that it is mileage only since I put very few miles on my 2008 335i e93 and I plan to keep it a while.
Old 06-24-2014, 02:44 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
No. BMW now understands the problems and can truly fix them.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 06-24-2014, 03:37 PM
Misterjim, I have to go into my dealership tomorrow and will ask SA and will attempt to call him right now to verify the 100K/ 10 years. I am pretty sure you are right but let's find out.
Old 06-24-2014, 04:13 PM
fun2drive's Avatar
BMWCCA 149159
CPO 100K miles/ 6 years from the date of purchase.
To identify the problem the late 2007 and early 2008 335's had some injector failures which should have been corrected by now. Turbos seldom fail unless you blow oil past the seals which you can do in this car when cold like 30's or below. The seals have a slight opening in the top and when cold the pressure relief valve doesn't do its job until warm so if you are hard on it cold the oil can and will push past the seals and you will start coking the turbo.
However if you just let the engine warm so the oil temp is off the mark you are fine. BMW was and is replacing the turbos for waste gate rattle which will typically go away when the engine is warm but is annoying when the engine is first started and warming up.
Some items you might want to keep in mind is the water pump and tstat life which is around 60K miles. ABS/DSC/Brake light issue with an issue tracked down to a Bosch electric motor that drives the hydraulic pump. Oil filter housing gasket will eventually leak and need replaced.
Not many cars can pull the power the 335 can and can be built up to be an impressive package.
Warranty to 100K or 6 years is helpful but you might want to look for a longer year warranty if you don't drive the miles out at the 6 year point...
Old 06-24-2014, 04:27 PM
BoldnDetermined BoldnDetermined is offline
Mein Auto: 2011 335i - X-Drive
Buy the car...get the extended warranty...drive hard.
BnD
Old 06-24-2014, 05:12 PM
I can't believe this is true, as I paid to have them replaced at 60K.
Are you saying they covered under original warranty up to 100K miles?
Old 06-24-2014, 06:02 PM
need4speed's Avatar
Some injectors are covered under the extended warranty, some are not. Check the model number/date to see if yours are from one of the problem batches. Mine for example were not, even though some injectors used during my car's model year were bad. HPFP and injectors are subject to a time element in the warranty as well as miles. I think it is 10 years. The waste gate/turbo is extened to 8 years and 80k (?). The wide spread issues are fixed by now. Anything new happening is a small chance bad part which can happen to any part. N4S
Old 06-25-2014, 05:53 AM
NJRbmw NJRbmw is offline
Mein Auto: 07 335i
hope im allowed to put this here but is this the right injectors, or a right injector needed? http://shop.advanceautoparts.com/p/b...932%7CL2*14985
comes with 3 year warranty/36,000 miles to
Old 06-25-2014, 06:50 AM
Turborascal Turborascal is offline
Canyon Carver
Mein Auto: 2011 E92 335is
Using the provided drop-down selector shows an "exact fit" for your '07 335i as well as for my '11 335is.
If tested and it doesn't fit, the fault lies with Advance Auto.
2011 Black Sapphire Metallic 335is Coupe | DCT | Luxury Pkg | Convenience Package | Cold Weather Package | iDrive/Nav/Sirius | Michelin Pilot Super Sports on 19" 313s
2015 Jet Black Metallic Porsche Cayman GTS | PDK | PASM | PTV | Sport Chrono | Power Steering Plus | Burmester sound w/nav | Park Assist with backup camera | Convenience Pkg
Old 06-25-2014, 09:00 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
I think the HPFP issues with the 335 gave the model a bad rap. Talking to my indy as well as reading the forums, the E90 is solid platform to include the 335.
Old 06-25-2014, 10:04 AM
I went to BMW South and was told that it is true, that the turbos and HPFP have an extended warranty of 10yr/100K miles. Nevertheless, I will try to get a copy of the factory bulletin.
Old 06-25-2014, 10:10 AM
Extended warranties
My indy shop recommends GMC, BMW South recommends EasyCare. Who bought an extended warranty?
