Old 06-23-2014, 09:48 PM
sandeepkarna sandeepkarna is offline
335ier...
Mein Auto: 335i 2009 AT sports model
Brake Fluid
Hi,
i have a 2009 335 i sedan recently had a service light for brake fluid at 43k miles , can you suggest whether to go with dealer or DIY? also whats the general cost with dealer?
Old 06-23-2014, 10:53 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Bavauto.com sells a kit and has a video on the DIY. Doesn't look too bad.
Old 06-24-2014, 03:27 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Dealer charges $80 for the job... 1 hour wait....
I go to dealer
Less hassle
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 06-24-2014, 07:59 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
If you look around (at least here) you can find it for $130 or so. I would go to the dealer. If you have what you need and a place to work, diys maight be better for you.
Old 06-24-2014, 09:00 AM
Mein Auto: '06 AW 330xi
I've found doing it yourself, never gets the pedal as firm as when the dealer does it. Even if you use a power bleeder, it's not as firm.
However, if you have BMW diagnostic tools, such as INPA or ISTA, you can activate the DSC hydro unit and bleed the brakes by activating the module. It will pulse the DSC hydro unit and help bleed the system.
I did this for my last brake fluid flush and the pedal is nice and firm.
Old 06-24-2014, 03:52 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
I've done it myself several times. Pretty easy to do, but you have to be comfortable monkeying around with your car, taking the wheels off, etc... If you don't enjoy it, or lack the confidence, it's much better to let the dealer do it. Be advised, brake fluid is nasty, nasty stuff. You don't want it to drip anywhere on anything.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
