Old 06-24-2014, 01:49 PM
recoil_id recoil_id is offline
Mein Auto: 2006 330I
Tire width.
I have the stock tire sizes on 2006 330i e90 255/35/r18 rear and 225/40r/18 my fronts are 8 inches wide and my rears are 8.5 wide could I but 18x8.5 wheels for the front and my current tire fit them?
Old 06-24-2014, 02:33 PM
flux45 flux45 is offline
Mein Auto: 2011 335xi
You will be fine. They might poke out a very tiny bit but they will fit easily.
I run 9 on 235 and 9.5 on 265.
Old 06-25-2014, 11:16 AM
mmkhalil10 mmkhalil10 is offline
Mein Auto:
I'm new to this forums. just bought a 2011 335i xdrive coupe with sports package last week so it has the same staggered wheels (front 225/40/18 and rear 255/35/18). I need to put new tires on...would I be able to put the 225/40/18 all around? I think it'll fit on the rim but can that mess with the xdrive system? or anything else?
Old 06-25-2014, 11:21 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
No. How do you expect to fit a wider tire on a more narrow wheel?
Old 06-25-2014, 11:25 AM
Mein Auto:
was told by belle tire that it shows as an acceptable alternate size when they put in the car. I'm probably gonna stick with the same size tires but was just wondering.
thank you
Old 06-25-2014, 12:38 PM
EnjoyDrivingMN EnjoyDrivingMN is offline
Mein Auto: 2011 335ix Coupe
He said he would try to put 225 size all around, which will make the tires a bit narrow for the rear wheels, right? Then, the rear tires would get a bit stretchy - just the way VW'ers love it
Old 06-25-2014, 04:59 PM
jummo's Avatar
jummo jummo is offline
False Enthusiast
Mein Auto: 14 435xi 14 X1 35i
This will work fine. The 1/2" width difference will not be a problem. If you look up a tire and then what size wheel will fit, you will see there is a range.
Enjoy your car!
jummo
"I know you were offended, but jummo's advice was sound."
Old 06-25-2014, 05:29 PM
Mein Auto:
I ended up getting the original size Michelin pilot PS2. definitely out a big hole in my account lol. thank you so much.
