Old 07-05-2014, 10:13 AM
mjs335 mjs335 is offline
Mein Auto: 335xi
Clock will not stay set
I have a 2008 335xi and every time I turn the engine off I have to reset the clock. I was wondering if a weak battery could be the cause? I have not changed the battery since I bought the car new. Anyone have any experience with this?
Old 07-05-2014, 12:01 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Yes, someone has experienced that. Usually just before battery replacement, PDQ!
Old 07-05-2014, 12:03 PM
Reregistered User
Oh, and set your Google to BMW battery checkout.
Old 10-29-2014, 05:46 AM
golfnut802's Avatar
golfnut802 golfnut802 is offline
Tee it up!!!!
Mein Auto: 2008 328xi
It does not happen every time....but occasionally I get in the care and have to reset the clock. I thought replacing the battery would eliminate the problem.....but EVEN AFTER getting the new battery it is still happening......thoughts anyone? Thanks.
Old 10-29-2014, 05:53 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
I would get a new battery asap. It is a classic warning sign, and the battery will just quit on you one day w/o any more warnings. N4S
Old 10-29-2014, 06:15 AM
Mein Auto: '06 AW 330xi
Did you have the battery registered?
Old 10-30-2014, 05:57 PM
golfnut802's Avatar
Tee it up!!!!
Yes, battery was registered and verified to ensure that it has a full charge
Old 10-30-2014, 09:21 PM
Reregistered User
Well, did you check the battery condition yesterday or today?
HERE
Mileage?
Charging system health?
When did clock resets begin again?
