Old 07-05-2014, 06:49 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2011 328ix
Direct injecdtion prob solved by some car makers
http://www.edmunds.com/autoobserver-...-adopters.html
what is Europe waiting for?
surely goodness and mercy will follow us all the days of our lives
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 07-05-2014, 09:23 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
I don't see where it was "solved". I must have missed something. Audi says its latest models have no "reported" build up but nothing shows that it was solved that I could see...
Old 07-05-2014, 10:45 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
Only thing that truly 'solves' the issue is some sort of filter/trap that isolates the crankcase gases and removes what precipitates out as crud on the intake valves. Something like a catch can on steroids.
Old 07-06-2014, 09:47 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Venting the crankcase gases directly to the atmosphere would also solve the issue, and it is what was done before PCV valves were mandated in the 70's. I wonder how problematic the release of the tiny amount of oily vapor would be?
Old 07-06-2014, 12:49 PM
The car would fail the hydrocarbon emissions test. Almost guaranteed to throw a code (crankcase pressure test fail). There would be eau de hydrocarbon that surrounded the car, which could cause problems if you were pulled over for even something as minor as a brake light being out. Your car could be impounded for emissions violations. Things could get expensive real fast.
The first emissions measure that was implemented for cars starting with the 1967 model year if memory serves was to vent crankcase vapors into the combustion process using PCV valves.
Disabling the PCV function would solve the carbonization problem, but liability for intentional disabling of the emissions system would far outweigh the costs of periodic de-carbonization.
Old 07-06-2014, 01:56 PM
Banned
Mein Auto: 2007-335 HTC
although I don't like government regulations, if you add up all the cars in the US then a few drops becomes thousands of tons of pollutants per year,
with the invention or regulation of PCV systems, and cleaning up the blow by gases one result was that engine oil last a whole lot longer.
My 71Triumph TR6 WO PVC, the oil is black after 3000 miles
give then time and they will come up with a system to keep valves clean
Maybe Teflon coat the valves and intake?????
Old 07-06-2014, 02:04 PM
Ever wonder why the manufacturer specified a 3,000 mile oil change interval?
It comes down to how much does the system to keep the valves clean cost versus the cost of the walnut blasting every 30K-ish miles. First 30K blasting is on BMW. The follow-on blasting would be paid for by the customer (either directly out-of-pocket or through purchase of extended maintenance coverage).
Personally, I think the solution is to be found in a super efficient catch can or filter that traps at a molecular level (think along the lines of GoreTex) that is replaced as a maintenance item.
Old 07-06-2014, 02:18 PM
misterjim's Avatar
misterjim misterjim is offline
Mein Auto: 08 335i 6MT convertible
It does sound like ford and gm have solutions for build up by timing of the injection pulse. The article also mentions re-designing the PVC system.
Old 07-06-2014, 05:19 PM
blue boy's Avatar
its a big $ for service dept
i drove the new 4 turbo and like the response but will not buy one at this time
THEY COULD PORT THE INTAKE AND DO A 10K CLEANING BY INJECTION AND SOLVE THE ISSUE BUT THAT WOULD BE EASY.
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
