Old 07-07-2014, 04:56 PM
Rafy27 Rafy27 is offline
BMW CCA
Mein Auto: 2006 330i E90
Adaptive Head Light failed
Well, I had this happen to me back in Feb went away after two days (I guess it was water). but it's happening again for two weeks, but the other day I noticed that the passenger side light is leveling when I start the car the and the only one not moving is the driver side. I though that both lights stop. does that mean that the one dead control unit is the driver side?
E90 330i
Member: BMW CCA
Old 07-07-2014, 06:30 PM
Mein Auto: '06 AW 330xi
Do you have the adaptive lighting error permanently in your cluster?
If so one of the modules have failed. Scanning the FRM will tell you which side. But if you're noticing the driver's side is not moving, it most likely that side.
Self leveling and adaptive are 2 independent systems.
Self check on start up (up and down movement) is to check the operation of the self leveling feature.
Adaptive is controlled by input from the SAS, steering angel sensor and does not show a visual self test.
Old 07-07-2014, 07:07 PM
BMW CCA
Well the warning comes up when I start the car and goes away then I get a green flashing light at the lights control (A). so the two systems are separate the leveling and the adaptive headlights?
E90 330i
Member: BMW CCA
