Old 07-13-2014, 01:51 PM
jzbrown jzbrown is offline
Mein Auto: 98 528
lost a sensor somehow anyone know which one center sensor in this pic is?
Replacing the head and have lost 2 nuts and now a sensor. Really thought I left all sensors attached to their wires. Not really sure how it could have got lost but it did. Center one is missing.
http://www.pelicanparts.com/BMW/tech...t/Pic11-01.jpg
Old 07-13-2014, 07:20 PM
bartelbe's Avatar
bartelbe bartelbe is offline
Mein Auto: 2xe39,e34,e32,e36
Interesting, I know both are temp sensors but the interesting part is I thought all 97-98 528i use the dual temp sensor. Meaning one sensor has 2 separate temp senders in 1. 1 for the instrument cluster and 1 for the dme. But it looks like you actually have 2 individual temp sensors. I cant tell you if the center one is for the IC or the dme but if you look at the wire colors I can proabley look at my Bentley.
Old 07-13-2014, 07:47 PM
Mein Auto: 98 528
i will do that tomorrow. They are different diameters so for sure different. Heck, i have a rats nest down there. I have the colors on the first one because it was attached, like I thought I did them all. I have the bentley, I will try to figure it out and then confirm here. Thanks for the info.
Old 07-13-2014, 08:21 PM
bartelbe's Avatar
Hold a sec I just realized the link is from pelican and not your actual pic which would explain the two temp sensors are e39 s us only one dual temp sensor. Is this yhe original head? If so It maybe best for you to take a pic if you cant find the sensor but for some reason I have a feeling that you didn't loose the sensor its just hidden. Theres about four sensors & 2 solenoids in that vicinity. Or if this isn't the original head the new head may have come off a older bmw that used 2 separate temp sensors in which case you would need to just install a plug in 1 of the holes..
Old 07-13-2014, 08:33 PM
Mein Auto: 98 528
you know that makes all the sense in the world. Rebuilt head was purchased on-line. It is not hidden at all. I will look through my pics of the head and see if I have a clear pic. probably not. I went crazy for an hour or more looking for something I do not think eists. Hopefully there are not any other crazy differences. Any I will check the mold number, or whatever they call it.
Wgosma's Avatar
Wgosma Wgosma is offline
Mein Auto: 2000 528i M-sport 5spd
Real OEM
You might want to grab that VIN no. and log on to http://realoem.com/bmw/select.do.
Bill in Oceanside, CA
Old 07-14-2014, 08:02 AM
Mein Auto: 98 528
Bill love those exploded views. Thanks.
Old 07-14-2014, 04:52 PM
Mein Auto: 98 528
Turns out I did have a pic with the plug. If you are trading out for a rebuilt, pull it before you send in the core.
Old 07-15-2014, 06:12 PM
Mein Auto: 98 528
Wow went to the dealer today to get a new plug, couple of nuts and a new water outlet, this one is coroded as all get out. Well, first part I asked for was the plug. Only 30 bucks!!! When I laughed and said its only a bolt, he laughed to and said he could give me a 50% discount. I did not get anything from them. Probably should have it was 12 bucks on line plus shipping for the items I ordered. As a side note - everyone says use oem thermostat so I got it from them a few weeks back without asking price first. It was 65 bucks, seemed a lot to me. But I did get free starbucks coffee while waiting.
Old 07-15-2014, 06:22 PM
bartelbe's Avatar
If you find a hydraulic fittings shop they should carry the plug. Cant remeber the size I want to say its a -4 bspp " British standard parallel pipe". Dont forget to get the copper crush washer or she'll leak.
Old 07-15-2014, 06:51 PM
Mein Auto: 98 528
bartlebe - my first thought was pull the sensor I have and go a local nuts and bolts place. But both sensors have different diameters. So I just got one on line.
