Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 07-14-2014, 12:04 PM
macindude macindude is offline
Mein Auto: 2000 528iT/5, 1988 325is
'95 M3 seems to lack low-end Torque
Hi all,
I just bought two 1995 M3's in roughish shape... Both cars have their plusses and minuses, and most issues I'll have no problem sorting on my own.
Both cars have Aftermarket exhaust systems and silly hot air intakes (unshielded cones).
The puzzle for me is that one car seems to make decent low end torque and the other car just doesn't. They are about the same past 3500 or 4000 RPM but one pulls noticeably harder from idle to the power-band.
I was told by the PO that the torquier car has a software tune, but my understanding is that the gains people experience from one-size-fits-all software tunes is mostly in the driver's head. Is it possible that software could account for this type of (very noticeable) difference?
Is it possible that this could be an issue with VANOS? What are the typical symptoms associated with a VANOS failure (I'm not getting any CEL)?
Any other ideas?
THANKS!!
Old 08-21-2014, 09:51 PM
Guam135i Guam135i is offline
Mein Auto: 08 135i Coupe
[QUOTE=macindude;8462022
Any other ideas?
THANKS!![/QUOTE]
same question here
1970 Morris Cooper S * 2008 BMW 135i Coupe * 2008 BMW 128i Cabriolet * 2003 BMW 525i Touring * 1995 BMW M3 Coupe
Old 08-23-2014, 09:44 AM
Snowxpert Snowxpert is offline
Mein Auto: Bmw 325ix BMW M3
The vanos does not kick in until 3500 rpms so that is not the issue. Maybe it's coil packs and fresher spark plugs in one
Old 08-26-2014, 05:26 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
wow!
helluva score.. I need to pick up a doppelgänger.
its called "maintenance"..
some get em.. some don't..
If its a "performance chip"..
It has a altered fuel map that will provide better off the line *feel*.
If you did a leak down test & compression you would probably notice some differences.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 12-26-2014, 02:47 AM
s50obd1stroker s50obd1stroker is offline
Mein Auto: 1995 M3
It takes like less than 5 minutes to check your DMEs . One will be cracked open and the other tab sealed.
