Old 07-15-2014, 05:30 AM
Tbear112 Tbear112 is offline
Mein Auto: 2008 bmw 328xi
Question Speaker problems
I have a 2008 bmw 328xi and the speakers pop like a heart beat. While driving the radio has a mind of its own, turning on and off by its own. Plus my usb port, aux, bluetooth and sos isn't working. I went to the dealership and they don't have a clue. Can someone please tell me what is wrong with my car ???
Old 07-15-2014, 06:30 AM
Mein Auto: '06 AW 330xi
If BMW Assist (SOS) is not working, there is a break in the MOST loop or the TCU is failing.
When a module on the MOST loop fails, it brings down the entire network.
So when you resolve your issue with this bus, it should resolve all the other issue since they are all on the MOST bus.
My guess is your TCU or head unit.
Old 07-15-2014, 07:12 AM
Where can I locate the tcu or head unit ?
Old 07-15-2014, 09:53 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
FYI note these are old documents
Head Unit =idrive or pro radio.
FYI note these are old documents and apply mostly to 06 and 07 cars with small changes
up to 09 and some larger ones after.
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/attach...2&d=1266451970
Most loop description in the following
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Also since its and 08 have you checked the battery or changed it ?
The IBS system is described in the above document, it can do strange stuff when going bad ?
Have you had the battery cable recall and if you did maybe they messed it up?
To eliminate modules you could put a most jumper on the radio or nav/idrive and see if the
sound or problem goes away. Then work through taking out each module in the same manner
to see if its the cause. But the battery and electrical system must function normally with just
the radio or idrive first.
Old 07-15-2014, 10:28 AM
wardlowk wardlowk is offline
Mein Auto: BMW 325i
Ironic I was just searching for a solution to my daughters '07 328i similar radio problem. She called last night to describe that her speakers starting popping and kept popping for a few minutes after the car was turned off and the key removed. When she started it back up later the radio did not work at all and the LCD display on the radio would not even light up. In the past on my '11 335i and her 328i when it has been real hot on a summer day after a long drive the radio has done something similar, spreakers start popping then the sound goes off but will start playing again after the car cools off (and the display never goes dark). My first thought is a blown fuse since the display is also dark - or could it be something more serious. The problem is she is 225 miles away and I can't get into it to see. Any thoughts before I send her to the shop$$? Thanks
Old 07-15-2014, 04:29 PM
Electronics in car do not power down right away.
And since some of the warning sounds can come through the
speakers the amp is not off even off when the radio is.
The Radio is never really off its just in do not play music mode.
If you lock the car it will cause it to go into sleep mode within a few
minutes turning off the amp. If you don't it can stay on as much as and hour if its
paired to a cell phone that's in range.
See the description in the last link for IBS system and Power distribution
and bus systems.
In an 06 or 07 that hasn't had a battery change its always a good idea
to check the battery first as 6 years is about all they last in a car that's regularly
driven moderate to long distances.
