Old 07-15-2014, 07:55 AM
BillyT0020 BillyT0020 is offline
Mein Auto: 2009 E92
E92 DSC Error 5E39 FFFF
Hey Guys,
Had a quick question for you regarding an error I'm getting with a DSC code, amber brake light, and DBC error (not abs). Cruise Control will not work when the lights are on. I cleaned the wheel sensors as well as the connections at the electrical box before I had INPA up and running and that seemed to help a little, but still getting it intermittently. INPA code says the following (see below). Can't seem to find anything on this specific error. I'm thinking the rear brake pads and sensor are probably due to be replaced, and may go that route first if I can't find anyone with any knowledge of this specific code. Any help would be greatly appreciated.
Thanks,
Billy
2009 328i E92
ERROR MEMORY
Date: 14.07.2014 16:21:55
JobStatus: OKAY
Variant: DSC_87
RESULT: 1 error in error memory !
5E39 FFFF- unknown error position
Error Counter : 8
Logistic counter: 40
Mileage 146944 km
Vehicle Speed 10.00 km/h
Brake Light Switch 1.00 0/1
Switch brake fluid level 0.00 0/1
ACS/DSC_aktive (status of ASC/DSC switch) 1.00 0/1
brake pressure identified 1.00 0/1
ABS-active 0.00 0/1
ASC-active (BMR) 0.00 0/1
ASC-active (AMR) 0.00 0/1
GMR-active (GMR) 0.00 0/1
CBC-active 0.00 0/1
MSR-active 0.00 0/1
TDR-active 0.00 0/1
SDR-active 0.00 0/1
DBC-active 0.00 0/1
RTA active 1.00 0/1
Run-Up Mode 0.00 0/1
No Matching error symptom.
Test Conditions Fulfilled
Error not present now, but already stored
Error would cause a warning lamp to light up
Error code: 5E 39 A0 08 28 47 C0 0A 29 00 04
