Old 07-15-2014, 12:58 PM
320sean 320sean is offline
Mein Auto: E90 320d
Unhappy dsc intermittent light
hi there,
my problem is that my car has a strange symptom,sometimes when i turn right on roundabout or round the corner the dsc light comes on and car looses the power,it never happens when i turn to left doesn't matter how hard,sometimes that light comes up at high speed at motorway when i push the accelerator all the way down,had it diagnosed but no fault codes,tyres are as new and pressure checked,is doesn't happen all the time but mostly when i stuck in heavy traffic,
is it dsc unit or wheel speed sensor?it's a 320d 2005,2l engine
thanks a lot
Old 07-16-2014, 06:43 AM
Mein Auto: '06 AW 330xi
If you have the DSC module scanned, it will tell if a wheel speed sensor is acting up. Even though there are no lights, the module will store shadow faults.
You need a BMW specific scanner to pull shadow faults. A generic scanner will not work
Old 07-16-2014, 09:37 AM
Mein Auto: E90 320d
ok update,took the wheel sensors off today for ispection and rear ones were worn as if they've been touching the abs ring.
probably they been causing dsc light to come on in different situations?
