Old 07-15-2014, 02:57 PM
bem-ster bem-ster is offline
Mein Auto: 2001 525i E39 M54 Engine
Fuel Pump Removal
2001 525i
Look at the 2 photos. The assembly came out according to the best links (first photo), however the pump separated for some unknown reason and remains in the tank (second photo)! The PUMP will not release from the tank and I do not want to force it and damage it. It acts as if it's attached to something else in the tank. Does anybody know how to get the pump out of the tank? What am I missing? Desperate and stuck on the side of the road.
Name:	5 Pump assembly.jpg
ID:	451863   Click image for larger version
Name:	6 pump in tank.jpg
Old 07-15-2014, 03:09 PM
cn90 cn90 is offline
http://www.bimmerfest.com/forums/sho....php?p=8428202
Two large plastic clamps hold the fuel pump down.
Old 07-15-2014, 06:50 PM
I have put my hand down in the tank to find these clips that you are talking about. I've squeezed every possible thing from every possible angle, while pulling up ward but NO GO. It will not release. Can you suggest what I'm suppose to be looking for. My tank is almost 3/4 full so the pump is submerged and I can't really see where these clips are supposed to be located. I was shocked when the flout came out and the pump was still in the tank. I thought it was all suppose to come out as ONE UNIT. Unfortunately I can't even get the float back in to reseal it for towing, I got to get this pump out, I just don't want to break anything, with 3/4 tank of gas it's going to be HEAVY.
Old 07-15-2014, 06:58 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I have never messed with mine, although it should be in my future since I habitually run the gas tank empty ... so all I can do is refer you to what pops up when I type /fuel pump f3 in the bestlinks:
- DIY for replacing the fuel pump (1)
See also:
- How does the E39 fuel injection FI system work (1) & the location of the K96 FPR fuel pump relay (1) & the location of the fuel system pressure test Schrader valve for the I6 (1) and V8 (1) (2) (3) & a quick test for fuel pump operation (1) (2) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (1) (2) (3) (4) (5) (6) (7) & a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to service your BMW E39 fuel injectors (1) & how to replace the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & cleaning the fuel gauge sensor (1) (2) & replacing the fuel sensor (1) & resolving blown fuses due to a stuck fuel filler door solenoid (1)
Old 07-15-2014, 07:04 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
Squeeze the 2 black clips towards one another and pump lifts out
http://i439.photobucket.com/albums/qq112/sauritch/9.jpg
http://i439.photobucket.com/albums/q...auritch/10.jpg
Old 07-15-2014, 07:39 PM
pshovest
What clips are you talking about? I've squeezed everything inside that pump cavity and nothing is giving. I appreciate the pics and I believe the two clips you are referring to are BLACK and I think I've found them but when I squeeze them the pump moves around but will not release!
Old 07-15-2014, 07:55 PM
BMW CCA 69606
I've put arrows on the clips. Clips are 180 deg apart. Push clips toward one another until they contact the pump. Lift out pump.
ID:	451888   Click image for larger version
Old 07-15-2014, 08:01 PM
I squeezed right where you are talking about, I've squeezed them from the top, I've followed those black tabs all the way down to the bottom and squeezed them there, that pump refuses to release. Should I just PULL it with all I got and hope for the best? That certainly doesn't seem the right way to go.
Old 07-15-2014, 08:05 PM
bluebee's Avatar
Originally Posted by bem-ster View Post
pshovest
Are you sure this aforementioned thread doesn't have a picture of what you need (even though the model is a different E39)?
- BMW 528i 1997 Fuel Pump replacemnt (Insert only) DIY
Old 07-15-2014, 08:32 PM
Thank you Bluebee
That first picture is what it should look like once the entire assembly is out of the tank. My problem is the "Pump Assembly" section is still IN the tank even though the Float Assembly is already out. I think the first pic, showing the whole unit removed really helps. Because those two black clips that appear on the pump housing unit should be squeezed together to release the Pump ASSEMBLE from inside the tank. I've squeezed both those clips but the pump assembly refuses to release! The PUMP is in the ASSEMBLY and the ASSEMBLY must come out as a unit to R&R the actually pump, if I understand the removal process correctly.
