Old 07-15-2014, 04:55 PM
kadey kadey is offline
Mein Auto: 97 528i
New start/battery, power cuts out...
Hello,
First post here, but I was a long time member of the old Roadfly forums. I have a '97 528i, and just replaced the starter (then the battery). When I turn the key to start the car, the engine does not turn over and the electrical power to the entire car cuts out. After a few minutes the power eventually comes back, and the same thing happens again when I try to start the car. Is there some kind of built-in protection that cuts off the power to the car when there's a really bad short (like a bad starter)?
Thanks.
Ken....
Old 07-15-2014, 05:56 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
it sounds like you have a loose connection.
when you turn the key to position (without starting it) does everything power on? I would clean the connections at the battery (power, ground and body ground) then check the connections at the starter and make its tight and not potentially contacting anything out of the norm.
I would be really shocked (get it? lol. I kill me) if it were something else.
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-15-2014, 06:17 PM
Mein Auto: 97 528i
Yes, everything is normal electrically when the key is in the on position: all the gauges and lights do their normal thing, I can hear the fuel pump pressurize the system, etc, etc.
I'll recheck all the connections.
So, any idea why all the power just disappears then comes back in a few minutes?
Ken....
Old 07-15-2014, 06:28 PM
helmet75's Avatar
thats a normal symptom of a bad connection. the load requirement of a connection when turning the engine over is very strong- a couple hundred amps.
to run the electrical system you need just a couple amps so a lesser connection is required.
once the load is cut, it causes a reset of sorts when the power is reapplied.
M5 Rear Sway Bar
Old 07-17-2014, 06:16 PM
Mein Auto: 97 528i
My car is running again...the problem was a bad battery ground cable.
Old 07-17-2014, 06:39 PM
helmet75's Avatar
sweet! nice and easy fix!
M5 Rear Sway Bar
Old 07-18-2014, 10:23 AM
Mein Auto: 97 528i
Yep. It took awhile to get it to fire up though. Gave me a scare, as it seemed to be turning over too easily, like there was insufficient compression. Then I remembered reading about cylinder wash, pulled and reinstalled 4 of the plugs, and it fired right up.
BTW, just so other folks know, I replaced the starter from the top of the engine and without removing the intake manifold. You actually don't need the E12 female torx bit either for the mounting bolts. A 10mm box wrench did the trick, and actually the really PITA part was removing/reconnecting the electrical connections.
Ken....
Old 07-18-2014, 11:01 AM
helmet75's Avatar
Thank you for the tips! Knock on wood I don't have to replace my starter
M5 Rear Sway Bar
