Old 07-15-2014, 06:09 PM
ARon335i ARon335i is offline
Mein Auto: BMW 335i
2009 335i CD Problem
Hi everyone,
I own a 2009 335i E92
There is a problem with sound on the CD
Radio works fine. Sound is there.
Aux works fine. Sound is there.
Bluetooth works fine. I can use my phone.
CD seems to work fine. It reads songs on regular discs. It reads files properly on MP3 cd-s. However, there is no sound from the speakers.
Does anyone know what could be the issue here? Thanks
Old 07-22-2014, 12:28 PM
Mein Auto: BMW 335i
I went to Parkview BMW in Toronto. They can't solve the problem quickly. Told me that I would have to replace the unit. Estimate at $1,213.85
I am sure that the solution is much simpler
Old 07-22-2014, 01:01 PM
Mein Auto: '06 AW 330xi
The optical eye for your CD drive drive is probably bad.
If you have nav, the drive is replaceable.
Not sure about the normal, non-nav HUs.
Look on eBay for used radios.
Old 07-22-2014, 02:17 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Pro Radio or I drive?
You might give these guys a call.
Repair
http://www.bmwradiorepair.com/?gclid...FccbQgodIEn0Cg
http://www.beckerautosound.com/BMW/index.html
I assume these same cd's work in other players that are capable of the format
they are recorded with.
If its a pro radio you can probably buy one for 400 to 500 bucks and some of the newer ones
have USB and bluetooth built in but require coding.
