Old 07-16-2014, 10:09 AM
aaronwitter23 aaronwitter23 is offline
Mein Auto: 2003 BMW 530I
Has anyone done a ofhg replacement on a 03 530i
Hello everyone, I am just curious if anyone in here has done a ofhg replacement. And if it's a pain in the butt to change. Please let me know. I am in need of one and just kinda wanna see what I have in front of me. Thanks, Aaron.
Old 07-16-2014, 10:11 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Aaron, do your duty: Search the E39 links at the top of the page. Much has been written on this topic.
BTW, if you are an adept shadetree mechanic, you s/b able to decide on the job based on an inspection of the area surrounding the canister.
Old 07-16-2014, 10:55 AM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
it's not terribly difficult, just requires patience and some experience working on the car.
follow the DIY in the links mentioned by Ed and you'll be able to accomplish it without too much cussing.
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-16-2014, 11:15 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
Not difficult at all.
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 07-16-2014, 12:41 PM
Ok thanks. Yeah me and my friend are going to tackle it. Thanks for the help.
Old 07-16-2014, 12:49 PM
cn90 cn90 is offline
Aluminum block, so be careful during installation.
Personally, I'd torque it with some Loctite and go down a tiny bit less than spec.
Some people have stripped the threads and have to do Timesert etc. Avoid this mistake.
Search forum!
Old 07-16-2014, 12:59 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Originally Posted by aaronwitter23 View Post
Ok thanks. Yeah me and my friend are going to tackle it. Thanks for the help. Sent from BimmerApp mobile app
In the "while you are in there" category, consider replacing the vanos oil hose at the same time. You have to remove the lower banjo fitting of this hose from the OFGH anyway, and this rubber hose is over ten years old now. They do spontaneously begin to leak at some point. If you want to go a little further, replace all of the idler and adjuster belt pulleys while you have the belts off. At least check them. . .
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 07-16-2014, 01:02 PM
Fudman's Avatar
Fudman Fudman is offline
Originally Posted by JKRIT View Post
In the "while you are in there" category, consider replacing the . . .
And the CCV.
Old 07-16-2014, 01:27 PM
trickstar trickstar is offline
Mein Auto: 2002 525i
Warping of the housing is an issue at times, preventing the best gasket from sealing.
Mine leaked after the new gasket was installed.
I decided to put a bead of Permatex Ultra Black RTV around the outside of the rubber gasket, between the gasket and the outside of the housing.
It worked great, but in the future, I'll try the Elastomeric "The Right Stuff" by Permatex.
This might save you from doing the job twice like I had to. These older cars often have the warping, and form a gasket can compensate for that, saving hundreds from replacing and machining parts.
Jimmy
