Old 07-16-2014, 03:02 PM
juanes3824 juanes3824 is offline
Mein Auto: 545i
2007 335i overheating
Hi guys I hope you can help me, my car started overheating on the way to work it showed the yellow water sign then turned to red and car turned off, but I made it to work, I left it parked until I got out, I checked coolant and it was topped off didn't have to put in any, so I drove home on limp mode for about 40 mins. And right when I got home it threw the signal again but no coolant leak. I just got back from a road trip to mexico roads aren't good. I'm lost please help, thanks!!!!
Old 07-16-2014, 03:20 PM
mike@x-ph.com mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Read codes....Im thinking it is fuel pump
EDIT : Sorry meant water pump
Old 07-16-2014, 03:21 PM
Mein Auto: 545i
But if it was fuel pump car wouldn't start, my car has no trouble starting up
Old 07-16-2014, 03:27 PM
Mein Auto: '06 AW 330xi
lol not fuel pump, it's your water pump that's failing.
Stop driving it. You can do more harm than good. Get it towed and have the pump and tstat replaced.
Old 07-16-2014, 03:32 PM
Mein Auto: 545i
Yeah thought so usually when it's fuel pump car won't start lol but my friend had same issue he said it was the water pump, it's so weird that it doesn't leak, it might just be the thermostat, it might no be letting water in, I noticed water level doesn't go down when I turn it on and the hoses are soft
Old 07-16-2014, 04:03 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
See here Driller, don't you know water is a fuel?
This mod will change everything in the next few months.
Old 07-16-2014, 09:02 PM
This is like the third time this happens, im thinking water pump and i write fuel pump
Old 07-16-2014, 09:40 PM
Mein Auto: 545i
What's weird is that it doesn't leak coolant, nothing! I can drive it for 40 mins straight!!! I don't want to change water pump if it's not water pump, to my understanding any water pump that goes bad will just throw the coolant out.
Old 07-16-2014, 11:15 PM
Group27's Avatar
Group27 Group27 is offline
Mein Auto: BMW 335i
BMW uses an electric water pump and most of the time it fails because the motor/impeller has frozen up and is not spinning. It would not leak coolant.
2008 335i M/T E93
2005 330Ci M/T E46
