Old 07-17-2014, 10:04 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
BMW E70 X5 - DIY and How-To Thread
I figured it may help to start indexing some of the DIYs and how-to to help new member navigate the website and hopefully cut down on the repeating questions
I encourage everyone to use this thread to point out relevant DIYs and How-to which I will then collect and update the initial threads: I'm really looking for contribution from everyone to make this useful (I don't want it to be MY thread, hopefully it can become OUR). I recommend everyone to refrain commenting or starting a new DIY here: it's best to comment each DIY in it's original post or by creating a new post for a new DIY. This is just for indexing purpose.
MAINTENANCE
Cabin filter replacement
Air filter replacement on 35d
Spark plugs
Tire wear and wheel alignment
DRIVETRAIN
Seal on power steering cap
Rear self leveling airbag replacement
Diagnosing diesel urea/SCR metering unit (post #26)
Engine partition, corroded injectors & fuel lines
X5 35d P205B - repair DEF level sensor
X5 35d - replace throttle body (P0638 and P2621)
INTERIOR & EXTERIOR
Driver side door pull
Airbag SRS cover swap
Resetting sunroof
Emergency brake (EMF) switch replacement
Alternative front license plate bracket
ELECTRICAL
NCSExpert coding
Final Stage Resistor / Blower Regulator Replacement
Rear entertainment screen repair
Battery replacement & registration
Replace headlight vertical aim adjuster motor (xenon headlight)
Upgrade gasket of the rear light on the tailgate
RETROFIT
OEM Trailer hitch installation
OEM Trailer brake installation
Aero kit installation
[Reserved]
Old 07-17-2014, 10:05 AM
[placeholder]
Old 07-17-2014, 10:58 AM
rh71 rh71 is offline
Among the Proud
Mein Auto: X5 3.0si
Good move... here's a few that are good:
Battery replacement - http://www.xoutpost.com/bmw-sav-foru...ement-diy.html
Aero kit install (pre-lci) - http://www.xoutpost.com/bmw-sav-foru...d-weekend.html
Spark plugs - http://www.xoutpost.com/bmw-sav-foru...e70-3-0si.html
Resetting sunroof - http://www.xoutpost.com/635045-post2.html
'08 X5 3.0si - Alpine White / Saddle Brown interior
Specs: Sport Pkg, Premium Pkg, Tech Pkg, Comfort Access, Aero Kit, Style 433 staggered 20s on Conti DWS
Mods: Carbon 35 tint, LED angel eyes, GP Thunder 7500k fogs, H&R 20mm/25mm spacers, clear reflectors, gunsmoke-tinted taillights
Coded: Digital speedo, windows/sunroof/tailgate close via keyfob
X5 pics at Flickr
Old 07-17-2014, 01:48 PM
lordshin808 lordshin808 is offline
Mein Auto: X5 4.8
Good one here for the
Parking brake / emergency brake (EMF) switch replacement
http://www.xoutpost.com/bmw-sav-foru...placement.html
Old 07-20-2014, 12:03 AM
HT417's Avatar
HT417 HT417 is offline
Mein Auto: 2008 BMW X5 3.0si
Can we get this stickied?
Old 07-21-2014, 05:05 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Jawohl.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 07-21-2014, 09:32 PM
HT417's Avatar
Originally Posted by MMME30W View Post
Jawohl.
Prima, danke!
Old 12-05-2014, 08:55 AM
bigblack06's Avatar
bigblack06 bigblack06 is offline
Mein Auto: BMW X5
Greatest thing to be added.
BMW X5 2013 35i Premium Black Sapphire Black Nevada Leather Tech Package, Cold Weather Package, Convenience Package, Xenon Headlights, Automatic Highbeams, LED Fogs, LED Interior Lights
2014 Lexus GS 350 F-Sport:http://www.clublexus.com/forums/buil...or-spring.html
"Faster, faster, faster, until the thrill of speed overcomes the fear of death…" – Hunter Thompson
Old 01-24-2015, 12:03 PM
lex450 lex450 is offline
Mein Auto:
DIY and How-To
I'm looking for a DIY on replacing the headlight washer nozzles on the E70.
Old 01-26-2015, 12:55 PM
Flying Ace Flying Ace is offline
Mein Auto: E90 M3; '12 X5 Diesel
anything DIY pictorials or video on changing engine oil on a X5d?
I've done it many times on my M3, just not sure if there's anything different on an X5, other than the fact the X5 doesn't have 2 drain bolts.
thanks.
Old 02-20-2015, 06:08 AM
scottysize's Avatar
scottysize scottysize is offline
Mein Auto: 2008 BMW X5 4.8i
Where's the oil change? I thought about doing my own sparks, but it's a V8, so I'm probably going to let my local BMW guy do that.
GONE: 2008 X5 4.8i
Old 02-20-2015, 08:03 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
Google is a good friend!
DIY: Changing Oil & Filter in a 35d
Old 02-20-2015, 08:12 AM
scottysize's Avatar
Thank you. I didn't know that 35d is the same process on my BMW. I'm guessing that is my engine number? I'm a fing nuby when it comes to BMWs.
GONE: 2008 X5 4.8i
Old 02-20-2015, 08:35 AM
scottysize's Avatar
So, I think I've figured out the 35d. That's the TDI version, which I don't have. I have the 8 cylinder which I'm thinking is the N62? I'd assume the oil change on the gas is different from the diesel. Or would that be wrong too? Hey, that's why I'm here guys. Compeltely new to me.
GONE: 2008 X5 4.8i
Old 02-20-2015, 08:40 AM
scottysize's Avatar
And if I'm right and I have an N62 engine, now I found the correct oil change procedure. Gracias!
http://www.bimmerfest.com/forums/sho...d.php?t=654029
GONE: 2008 X5 4.8i
Old 02-22-2015, 02:30 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Front brake pads, rotors, sensor, and reset from "AskTheCarExperts". This guy is always very detailed. I followed his videos when I did the cooling system refresh on the E46 and the level of detail was invaluable.
Old 02-22-2015, 05:27 PM
scottysize's Avatar
Nice Find!
GONE: 2008 X5 4.8i
Old 03-18-2015, 03:23 PM
kleanerman kleanerman is offline
Mein Auto: 2011 X5 XDrive50i
This is a fantastic informative video.!!!!! mine has 65K miles.....Do I need to change the Rotors? What is the criteria for determining that?
Old 03-25-2015, 10:33 AM
Sam617 Sam617 is offline
Mein Auto: X5
No DIY on coolant expansion tank on a 4.8?
Old 03-29-2015, 04:33 AM
Rollatron Rollatron is offline
Mein Auto: 2011 X5 E70 35i, 2001 330
Exclamation
I've searched the Google machine for thermostat replacement to no avail. Anyone have a DIY for this?
Old 03-29-2015, 09:10 AM
Google "DIY bmw e70 thermostat replacement"
Here is sample hit . . . may not be your exact engine . . . but once you get a general idea you should be able to improvise . . .
BMW X5 Thermostat Replacement
GL
Old 05-31-2015, 11:55 AM
Gixxerboy63 Gixxerboy63 is offline
Mein Auto: e34 540i/6 Msport GA65474
Headlight removal, LED retrofit, lens replacement anyone?
'95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
ESS supercharged/cooled, AEM controller, JBR flywheel, DSSR, short shift kit, 3.15 rear, Full Custom Stainless exhaust, RD sways, RD strut brace, Koni/Vogtland, Hartge e34 specific staggared 18" 3-piece wheels. 397rwhp /404lb-ft
Old 11-01-2015, 06:46 PM
footballer88 footballer88 is online now
Footballer88
Mein Auto: 2007 BMW X5 4.8i sport pk
Exclamation
I'm starting to get desperate here. I'm running windows 8.1 (new laptop, go figure) and the IMPA 5.0 I've installed it's working at all. Even the EDIABAS 6.47 isn't installing properly.
I'm trying to register the '07 4.8i that the DYI is set in, but it's not working.
Can anyone please redirect me on a path that can lead me to successful installation of the software? I have the OBD to USB cable and the CD with the software (E-bay/China bought). Looks good, with mainly German instructions but still nothing....
2015 -- Silver 2007 BWM X5 4.8i sport pkg+ wide rims
2014 -- Black 2014 Ford Fusion SE Ecoboost 1.5L traded
2013 -- Black 2010 Dodge Nitro SXT 3.7L sold
2013 -- White 2013 Subaru Crosstrek 2.0L wife car
2012 -- Blue 2003 Mercedes Kompressor 2.0L sold
2010 -- Beige 2008 Mazda Tribute 3.0L sold
2009 -- Blue 2003 Mazda Protege5 2.0L sold
2005 -- Silver 1995 Volvo 960 wagon 3.0L totalled
-- High Speed, Low Drag --
Old 11-28-2015, 10:22 AM
SpeedFrK SpeedFrK is offline
Mein Auto: 2010 X5 xdrive48i
Upper radiator hose replacement?
Anyone seen instructions to replace the upper radiator hose on the 4.8 N62 motor? I can figure out how to get at and remove the hose but it seems like the BMW clamps require a special tool, can anyone verify? The new part images have the clamps on there but I have looked at then on my car and they seem crimped. Maybe just some images on how to remove the old and set the tension on the new ones?
