Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 07-17-2014, 10:50 AM
michiuk michiuk is offline
Mein Auto: BMW 530D GT
main shell bearings
Hi My m3 goes in for diagnostic on shell bearing rattle when engine under load next week
it is not a pronounced rattle but when engine gets up to temp and is under load there is the bearing rattle for all to hear I hope this is a case of suspension down and sump off to get at the shells to replace
Old 07-23-2014, 03:14 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Main bearings or rod bearings?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-25-2014, 04:11 PM
rolfjahn rolfjahn is offline
Mein Auto: M3/335/911 G50s/911 Turbo
anything on cold startup? Had a motor replaced from that wonderful noise...
Old 08-08-2014, 11:10 AM
not sure it sounds like end bearings they rattle when engine hot and under load
Old 08-30-2014, 02:42 PM
ingenieur ingenieur is offline
Mein Auto: 328d
Did the dealer repair this? How many miles are on your M?
Country Roads take me home...
