E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#776
I have an 08 328i, my Touch HTC with sprint works great. I don't think I am able to do SMS.
08 328i/Sparkling Grap Met/Navi/Prem Pack/Auto Step/heated front seats/ipod/usb
#777
BT information not very well figured-out
The bmwusa web site gives information about BT phones which is not wery well figured-out, as one may buy a cellular phone in Europe, for example, which will not appear in the listing on the bmwusa web site. Namely, I have Mototola SLVR L7, which is a T-Mobile's phone in Europe, while in the US it is exclusively AT&T's. In addition, my phone's software still fully works with my 325i regardless of being older than what has been specified in the compatibility chart under AT&T's SLVR. Which reders this web site pretty useless. I believe that most of the cellular phone providers will let you try to connect the phone to your car before you buy it. I understand that it may not be fun, because it will casue a lot of back and forth if the phone proves not to be compatible, but still, one will not be forced to buy something and then have it not working. THIS IS VERY FRUSTRATING!
#778
Trial and Error
The idea to check and see if the phone works before buying sounds good unless you buy into the fact that it might work for awhile and then cause major problems. I spoke with our local BMW bluetooth expert at our dealership and he told me that if I used my Treo it would work fine for awhile and then shut my I Drive down. He said to only use the phones on the list. Well as I said before you cannot buy ANY of the phones on the list at the local Sprint dealer. Well I went ahead and Paired my Sons MuZIQ sprint phone ands it works fine. It did not however bring in the contacts. I have bought a phone from the list on EBAY and will let you know how that goes.
#779
Re TBB13
Your case actually should have prompted BMW to really try to keep the BT compatibility list always updated and correct, in addition to me noting that it should also include cellular phones not just sold in the US, because some of US have the opportunities to buy our cellular phones elsewhere! I hope that BMW is also listening to this, and I believe that this is not too much of a weird request for them! |
#780
See: http://www.wireless4bmw.com/ |
#781
Phone model:
Car model: 2008 528i [X] ability to make/receive calls [ ] phone book automatically synches to car [ ] dial by name (without verbal training of system) [ ] calling name display (using adddress book) [ ] ability to send/receive SMS I have a Palm Treo 750 with AT&T. Phone will sync and I can make/receive calls. I can get the "Quick Dial" numbers on the phone's main screen synced to the car, but not the address book - go figure. So I just have lots of Quick Dials! |
#782
HTC Touch
Do you have WM5 or WM6 in your touch? My locks up every time the bluetooth connects after the connection is done (IE the car is shut off).
Thanks.
Drive Fast, Take Chances. BMW 535XI, Jet Black |
#783
I have a 08 535i, my Nokia E65 pairs with the car and I can make and receive calls but cannot access address book. Any ideas?
#784
Hey Mail77 it is somthing to do with the Symbian software in the latest Nokia phones thats not compatable with the BMW Bluetooth.
I found this workaround on another forum, try it and let me know how you go. Hi All, Just bought a Nokia n95 and I paired it to my Gen3 ULF last night and transfered the phonebook. Here's how to get the phone book across. (its a bit fiddly but works) If you have already paired the phone (n95), then delete the paring on the phone. Start the paring process again; Press and hold the pair button, Turn on ignition (stage 1), Wait 3 seconds, release pair button, ULF goes to paring mode, Search and find ULF, Select and input code, Confirm pairing and connect, (this is normally where you then switch off the ignition to save the pair, DON'T) While still in the pairing/connected mode go to the "contacts" on the phone, Mark 10/15 contacts and use send business card -> via blue-tooth -> bmwxxxxx, Then select another 10/15 and same again until all the contacts are transfered, When finished the turn off the ignition to save the pair and address book transfer. Wait until the phone disconnects with the car, then turn on ignition and hey presto the phone book is available. This should work for any symbian phone, no SMS but thats no biggy |
#785
Sanyo Katana DLX on Sprint with New 535i
Well.. Today I took a chance. Stopped by the Sprint Store and picked up a Sanyo Katana DLX phone.
I decided on the Katana since I was looking for a good all around phone with Bluetooth. Didn't need a PDA Phone, and the overall reviews of the Katana DLX I read on the web were favorable. My initial experience was positive with the 535i's iDrive / Hands Free system. I haven't done an extensive check of all possible features, but the following basics worked first try: 1) Phone paired with the car. 2) Address book downloaded successfully to the car. Entries with multiple phone numbers in the phone's address book came into the car as multiple instances of the same name - but with a qualifier on the end for home, mobile, work, etc. like: Alan (H) Alan (M) Alan (W) 3) I could place calls using the iDrive menus and address book in the car. 4) I could receive incoming calls and answer them using the controls on the steering wheel. I did not test other functionality, but was excited to get this far in the first 5 minutes. I will do more extensive testing and report back when I have more complete info to share.
#786
Bluetooth Compatible
The BlackBerry Pearl (Research In Motion 8100) appears to be fully compatible, at least with a 2006 525i. The only glitch I had was the device access number, but when I was told you can enter any four digit number with BMWs it solved the problem.
#787
Since there seams to be a serious lack of good info about currently available Sprint cell phones that work with BMW hands-free, here's my attempt at following Jonathan Spiro's format (see Bmwcca.org) for reviewing the Sanyo Katana Dlx.
I was really nervous about picking a phone, given the finiky nature of phones and hands-free car systems. But Saturday I took a gamble and picked up a new Sanyo Katana Dlx. I won't go into the phone itself other than to say I really like it - I did some web research ahead of time and there are plenty of good reviews of this phone. For the most part it gets high marks from those who have been using it for a while. The areas it was given lower marks were things I won't use much anyway. Anyway for those who are looking for a good phone (Not PDA) with plenty of features and works well with BMW's car system (At least the 2008 535i), here you go.... Beware, though... I've only been using the phone with the car for 3 days. So far no issues. I've read that some phones may work for a while, then stop working with the car. So in that respect, the jury is still out on this one. But I'm cautiously optimistic and even more hopeful that won't happen here. Phone: Sanyo Katana Dlx Carrier: Sprint Car Tested: 2008 BMW 535i (no Navigation Package) Bluetooth cell phone test results: Sound Quality: 8 Mobile pairs to car: Yes Audio (receive/transmit): Yes Transfer of phone book: Yes (See Note 1) Place calls using dial by number: Yes Receive calls: Yes Display of signal strength: Yes Place calls via speech recognition (i.e. dial by name): Yes (see note 2) Caller ID for incoming calls - what shows up on display: Name (if number matches entry in phone book), otherwise number. Rings through vehicle: Yes Send/end call: Yes Phone Info: Software Rev: 1.010SP Hardware: 0203 PRL: 60610 Notes: 1) Address book transferred completely. When a Katana phone book entry had multiple numbers for a name- e.g. home, work, and mobile, the iDrive menu showed each separately like this: John (H)2) Because I didn't have the NAV option, I had to manually set up voice dial name/number entries per the BMW manual instructions. Worked fine.
#788
I just traded in my Blackberry Pearl (8100) for a Curve (8320). Absolutely no trouble pairing the Curve with my '05 545i. Address book was there immediately.
-Will 2005 545i Sport | 2001 X5 3.0 Sport (Retired) |
#789
I recently bought a 2005 330ci with nav and also have an LG vx9900 (EnV). I did not receive the phone manual with the car and wondered if anyone can let me know how to set up the car to work with my phone. I have been going through all the menus and have not seen anything that sounds like it has to do with pairing the two.
#790
2013 X5 35i Premium, Space Gray, Cinnamon Brown Leather, Dark Bamboo wood trim, Conv. Pkg, CWP, Multi-contour seats, Running board, BMW App. Space saver tire. 2010 535i - Deep Sea Blue w/ NBD Leather, Bamboo Anthracite WT, Sport Auto Trans w/ Paddle shifter, Sports Pkg, PP, CWP, Nav, HD Radio, Ipod. - Returned 2007 525i - Black Sapphire Metallic, Black Nevada Leather, Premium package, CWP, 6MT. - Returned |
#793
AT&T Tilt with 2005 545i
I was looking for this info before I bought my car so I thought I should post it after purchasing and trying it out.
I successfully paired my AT&T Tilt (aka HTC Kaiser aka HTC TyTN II) with my 2005 545. As far as I can tell right now everything is working well....the sound is good...just an occasional crackle but hard to tell right now if it’s the Bluetooth or something at the other end of the line. The address book seems to be there as well at least all the contacts I needed so far! |
#795
LG Flare ??
Virgin Mobile has started selling the LG Flare.
It supports these Bluetooth Profiles: Headset (HSP) / Handsfree (HFP) / Dial-up networking (DUN) / Object Push (OPP) / Generic Access (GAP) / Serial Port (SPP) / Service Discovery Application (SDAP) Do you think it might work in an E93? |
#796
Blackberry 8130 (Verizon)
Any tips on this...
Blackberry Pearl 8130 (Verizon) While at the dealer, the tech helped me pair up my phone. Everything worked; even the address book, caller-id etc... Got in the car this morning; no address book. Just a giant speaker phone! I went thru the setup from scratch... Nothing! Any ideas on why my address book worked, among all other cool features, and today its not there? ![]() Thanks! Tom
---------------------- Kaneohe, Hawaii 2000 Z3M Roadster |
#797
It worked fine with my Pearl, except occasionally the address book did not come across - like 4 times in 4 months. Generally, the next time I got into the car, it was there again.
#798
Yup, it came back... I think it has something to do with the size of your address book. It takes some "time" for it to transfer if its larger... I think thats what it is anyway. Mahalo, Tom
#799
what works for the new 135 1 series??
Just got my 135 and want to get bluetooth working any suggestions for the compatible phone Thank you
#800
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Which bluetooth BMW 7/5 series compatible phones work in Europe? | neurom | European Delivery | 22 | 04-02-2005 01:15 PM |
| are Chinese language cell phones compatible with BMW bluetooth?? | alsu1983 | 3 Series / 4 Series | 1 | 01-15-2005 02:45 PM |
| BMW Update for S54 Engines | BMWNA | M Series | 2 | 08-13-2003 05:55 PM |
