Old 07-19-2014, 06:21 PM
turboracing350z turboracing350z is offline
twintturbo
Mein Auto: 2008 BMW 335i
Water leak..
My 2008 335i Sedan..Click image for larger version
ID:	452776Click image for larger version
ID:	452777started randomly leaking water today under the passengers side of the car? Anyone experienced this before? The only thing I remember using today was the water from the windshield whipers today..? Hopefully it's that....?
Old 07-19-2014, 06:28 PM
twintturbo
Just drove it around used the whiper fluid to clean the windows again while driving. Parked the car and now both sides are leaking. So I think it's the whiper fluid ?
Old 07-19-2014, 07:34 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by turboracing350z View Post
Attachment 452778
Try Googling that - lots o'info around about leaks in tank area.
Old 07-19-2014, 07:37 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Lift the hood and have someone operate the wiper fluid and see if you can see it squirting anywhere in there.
Old 07-20-2014, 12:45 AM
twintturbo
Thanks!!
2008 BMW 335i Sedan
Old 07-21-2014, 06:13 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Water leak..
I just replaced my wiper fluid pump last weekend. If it is any help for you, with me the pump would only leak after I had used it and pressurized the lines. Swapped out the pump and now everything is okay.
You can order off brand pumps for far less than the OEM one on Pelican Parts.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 07-21-2014, 07:12 AM
Mein Auto: '06 AW 330xi
Does the liquid leaking smell like alcohol/nail polish remover?
If it does, it'a pretty good indication that it's washer fluid.
Might be a disconnected/damaged line or a washer jet that is clogged or jambed.
Old 07-21-2014, 08:24 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
This was my guess too. N4S
Old 07-21-2014, 09:57 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
It was the pump on my wife's X3 - since sold. Bought replacements from Amazon. A $50 fix. Pull the tank, replace the pump - and you are done.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 07-28-2014, 02:27 AM
twintturbo
It just smells like water?
2008 BMW 335i Sedan
Old 07-28-2014, 02:28 AM
twintturbo
Thanks for the tip man!!
2008 BMW 335i Sedan
Old 07-28-2014, 05:07 AM
richbmw richbmw is offline
Mein Auto: '11 e92 328i 6MT
Had the exact same thing 2 mos. ago. Called dealer (100 miles away) was advised if no warning lights, just keep eye on washer fluid level. Two days later and more water leaking, (double to triple yours) drove to dealer. They checked everything couldn't find any malfunction. They took me to the car which was on a lift and showed me the plastic protective covering which runs under the engine area and explained that although it does serve to protect somewhat, it also tends to hold water at times (after washing etc,) build up and will leak out. He then pulled the edge of the plastic down a little and sure enough water began to drip out. It made sense at the time, but on the drive home couldn't understand why I never noticed it before if that's what it was. In the end, it dripped a little for a couple days and for the last 2 months, nothing except normal air conditioning dripping. On a side note, right before I finally took it to the dealer I parked on a lot which was down slanted towards the pass. door, and upon returning, the most water to date was noticed behind the tire. Although this seems to confirm the dealers point of view, I still wonder why I never noticed it before.
Old 09-25-2014, 04:47 PM
ggevox ggevox is offline
Mein Auto: 2011 328ix, 2008 Lan GSR
Any part number or link to that pump. I believe mine is doing this exact issue. Only when pressurized. Pours all out. SMH
