Old 07-20-2014, 07:53 AM
WeekendGolfer WeekendGolfer is offline
Mein Auto: 335i
Safe to mix Engine Oil?
Hey all,
I bought a pre-owned 2009 BMW 335i about 3 months ago and I'm not sure which oil it currently has in the engine. The light came on yesterday letting me know that it is low on oil, told me to add 1 quart. It isn't due for an oil change for another few thousand miles..I'm not sure which brand/grade to go out and purchase to put in the engine, or if it would be bad for the engine for me to mix in a different brand with what's currently in it.
anyone have any ideas? dealership is closed today and I want to get it taken care of.
Old 07-20-2014, 08:06 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Originally Posted by WeekendGolfer View Post
Hey all,
Any BMW approved oil will work - see your Owner's Manual and visit O'Reilly's.
Old 07-20-2014, 08:14 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Easiest approved oil to find is typically Mobil 0W40 full synthetic - walmart even has it. No worries mixing as long as you are using a BMW approved synthetic.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 07-20-2014, 01:57 PM
avocet avocet is offline
Mein Auto: '07 328i
if you are just topping off to get to your next scheduled change or are in a pinch, you can add ANY sae automotive engine oil and have NO compatibiliy issues. synth and non synth oils will blend together just fine.
Old 07-20-2014, 03:01 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
In fact the owner's manual mentions this--that you can use a small amount of non-approved oil as a top off.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 07-20-2014, 03:03 PM
galahad05's Avatar
Better with Butter
For example, the 2011 335i coupe/convertible owner's manual, page 225:
"Alternative oil types
If approved oils are not available, you can use
quantities of up to 1 US quart/1 liter of another
oil with the following specifications:
API SM or higher
BMW recommends Castrol"
-- Irish Proverb
Old 07-20-2014, 03:16 PM
jamcousi9 jamcousi9 is offline
Mein Auto: 540I
Aren't we supposed to run 10 weight in these cars?
Old 07-20-2014, 03:48 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
No. E90 OEM is 5w30 BMW branded synthetic. And Mobil 1 0w40 is also fine (but not 5w30).
Tom
Old 07-20-2014, 04:02 PM
Mein Auto: 540I
I've heard more than once that 10 weight is better in higher (80k+) mile vehicles.. I notice the 335i tends to run a tad high in temperature so running a thicker viscosity oil would make more sense this way it stays thicker under higher temps.
Old 07-20-2014, 04:34 PM
galahad05's Avatar
Better with Butter
0 or 10 -- that's the cold weight (viscosity).
-- Irish Proverb
Old 07-20-2014, 09:47 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Oh, for chrissakes, the OP said he was going to change the oil in a few thousand miles and was down a quart. I would bet a kidney that adding nearly any modern multi-weight oil certified by the SAE or API for gasoline engines would have no measurable effect on wear or performance compared to the few oils consecrated by the Holy Bayerische Motoren Werke.
Unless he/she is about to attempt a land speed record or entering the Paris to Dakar Rally then they will be fine with whatever gasoline engine specified oil is on the shelf at the local parts store. Even then I doubt it would make any appreciable difference.
Old 07-20-2014, 10:09 PM
pauljcl pauljcl is offline
Mein Auto: '11-335i conv., 09RX350
+1, agree.
