Old 07-20-2014, 01:35 PM
turboracing350z turboracing350z is offline
twintturbo
Mein Auto: 2008 BMW 335i
Washer Fluid Leak
Has anyone had this problem before? I used my washers yesterday to clean the windows.. When I was done I noticed the water leaking from under the car.. Meaning the water that was sprayed from the car leaked down being normal couse it has to go somewhere..But it stayed leaking all day... Today the car said Washer Fluid Low??
2008 BMW 335i Sedan
Old 07-20-2014, 01:38 PM
twintturbo
Washer Fluid Leak
2008 BMW 335i Sedan
Old 07-20-2014, 01:49 PM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
Attachment 452879
2008 BMW 335i Sedan
Looks like a washer reservoir leak. The tank is located in the fender right behind the tire.
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats
Old 07-20-2014, 01:59 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Y'know, I seem to remember this once or twice. Try Googling!
Old 07-20-2014, 04:29 PM
White94RX White94RX is offline
Mein Auto: E39 540
The pumps leak, not the tanks. And it's super common. I replace them all the time at work
BMW Level 1 Master Tech
2006 E60 M5
2006 E60 525i
2001 E39 540i (sold!)
BMW Level 1 Master Certified
2001 BMW 540i
Old 07-20-2014, 05:23 PM
Fish23's Avatar
Fish23 Fish23 is offline
Mein Auto: 2014 BMW 535xi GT
If it stayed leaking that long, one would have to suspect the reservoir first and then work towards the pimp and then the flluid outlets at the windshield. Perhaps a hose came loose on the supply side of the pump that slowly drained fluid from the from the reservoir.
It is a fairly simple system but perhaps hose routing makes tracking down the leak source challenging.
Good luck.......
Sent from BimmerApp mobile appo
Old 07-20-2014, 06:16 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
If I understand this correctly, the reservoir/pump leaking is a result of using generic (ammonia containing) washer fluid. We ran into this recently with our MB. Tank had to be replaced. Indy cautioned to only use "approved" washer fluid.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 07-20-2014, 06:21 PM
twintturbo
Thanks.. Ima try looking for the leak & see what I find.
2008 BMW 335i Sedan
Old 07-20-2014, 06:26 PM
twintturbo
Thanks!! I'll try looking for the leak.. Let's see what happens
2008 BMW 335i Sedan
Old 10-13-2015, 12:45 PM
donomiller donomiller is offline
Mein Auto: 335i convertible
Turbo what did you find? I have the same issue
Old 10-13-2015, 12:58 PM
vytama vytama is offline
Mein Auto: 13 535 M-sport & 07 328xi
I have had couple issues with washer leaks: couple years ago I replaced the pump because of leak and about a month ago - filler hose which was cracked in multiple places and would leak while filling up.
Old 10-13-2015, 03:15 PM
Wongway Wongway is offline
Mein Auto: 2011 E90
Ahh, good thing to keep note of and look out for, thanks!
Old 10-13-2015, 05:52 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Not only is the pump a cheaper place to start, but statistically speaking it is the most likely based on responses here to be the problem. ...and then there's he fact that is what it was with my car so therefore it must be that.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-13-2015, 06:34 PM
tony(topaz,SMG)'s Avatar
tony(topaz,SMG) tony(topaz,SMG) is offline
Mein Auto: '11 335i,'88 M3, '15 X5,
Mine was leaking from the pump. it's easily removed from the reservoir and the replacement was fairly cheap.
Old 10-14-2015, 07:15 AM
need4speed's Avatar
need4speed need4speed is online now
Mein Auto: 16 435 CV Msport PPK/335d
common issue. I had mine replaced in Feb. N4S
Old 10-14-2015, 11:12 AM
Mein Auto: 2011 E90
I haven't really googled hard yet, though I get the impression you need to remove the passenger front wheel and wheel lining to get access to that pump to replace?
The last time I had to do this, was on my E83, and that was way easier to access. Just pop open the hood and unscrew the bolt and pull the reservoir out.
Mein Auto: 2011 E90
edit:
Sorry for the double post. Comcast's sporadic outages out here at the moment for some strange reason...
Old 10-14-2015, 11:36 AM
bocabimmer's Avatar
Yup. That's it. After a couple times it can be done in a matter of minutes.
2014 i3 BEV
Old 10-14-2015, 11:56 AM
Big Ace's Avatar
Big Ace Big Ace is offline
BMW CCA #405768
Mein Auto: 2015 435i Gran Coupe
When I had my '08 E39 I had the same problem. It was a washer between the tank and the pump. It was a quick fix, but a pain in the neck.
=Allan=
