Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 07-20-2014, 11:30 PM
LOES-E21 LOES-E21 is offline
Mein Auto: 1982 BMW 320i
Question Restoring Dad's 1982 320i
I'm restoring my dad's 320i. He told me it had been running fine when he stopped driving it. But that was about 15 years ago. I'm not concerned about any kind of cosmetic work right now but I have a few questions about the engine.
So far, I've replaced the spark plugs, rotor, distributor cap, battery, fuel, and oil. The engine will crank but it won't start. I checked all the spark plugs and they're getting spark and connected in the proper order. The air filter is pretty clean. I've tried spraying starting fluid into the air intake and that didn't work either (which means fuel is not my problem, correct?).
Does this mean it's compression? I'd imagine the gaskets will have dried up and cracked over fifteen years, wouldn't they? I did check the rocker cover gasket and that was in pretty decent shape, though.
I'd just like to do everything I possibly can on my own before I have to take it in to a mechanic. What should I try next?
Old 07-22-2014, 02:04 PM
Dev893 Dev893 is offline
Mein Auto: 1981 BMW 320i
make sure the Positive and Negative cables are connected properly to the battery and make sure there is no corrosion
Old 09-19-2014, 09:45 AM
goldenbb goldenbb is offline
Mein Auto: 2013 328xi & 1990 325is
That's not exactly "restoring." Did you get it running?
Old 09-19-2014, 03:34 PM
It is exactly 'restoring.' Getting the engine running properly is a very important part of restoration. Unless you just want a pretty car that sits on a shelf and can't start, which is something in which I am in no way interested. I prefer driving cars over looking at them.
Old 09-19-2014, 04:20 PM
Sorry. When I think of restoration, I think of pulling the engine completely out, cleaning it, replacing all the seals and gaskets at the very least, if not a full rebuild. Wasn't trying to be rude or anything. If this is your start of a really fun project, that's great.
Old 09-21-2014, 09:16 AM
dogez1 dogez1 is offline
Mein Auto: Ford F150
I tried that once
I attempted to get a '79 320i running back in high school. I worked for weeks trying to get it to crank. After replacing many components in the mechanical fuel injection system ( and deciding that was too hard for a novice like me to work on) I pulled the whole system off, bought an intake and Solex carburetor from an older 2002 from Ebay, installed it, and it cranked right up.
That certainly wouldn't be an original restoration, but if you are just a reasonable person who wants to enjoy working on and driving the car, its a thought.
I actually have the engine for sale now. I haven't cranked it in about 8 years but it ran then.
I think I paid about $125 for the intake/carb then.
1982 320i, e21, engine, no-start, restore
