Old 07-23-2014, 07:02 PM
bracer028 bracer028 is offline
Mein Auto: 2007 328i
2007 328i fuel gauge problem
have any of you had this problem. The fuel gauge was going haywire and just going all over the place.
I talked to an INDY and they said the gauge is located in the fuel tank and that the whole thing needs to be replaced.
What should i do. He said it costs about 1300 to fix.
Old 07-23-2014, 07:36 PM
GG Hyundai GG Hyundai is offline
Mein Auto: '08 328xi
Pay them $1300.
Old 07-23-2014, 07:50 PM
I dont trust them. No way you need to replace the whole tank for a gauge problem
I just want to confirm with others.
The car is worth like 7000...why would i spend 1300
Old 07-23-2014, 07:52 PM
Because maintenance and repair costs don't depreciate.
Old 07-23-2014, 08:03 PM
its worse...its a sunk cost.
Old 07-23-2014, 08:04 PM
Yeah I know
Old 07-23-2014, 08:51 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Step 1 is to ignore GG Hyundai's "advice", and open realoem. Looking at the fuel tank, the level sensor is built into a fuel pump. So find your car on realoem, and figure out which part number you need, and order it.
Example: http://www.ecstuning.com/BMW-E92-335...189/ES2702296/
No idea why your indy wants to replace the entire fuel tank.
Once you get the pump/sender unit, follow this DIY
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Old 07-24-2014, 07:47 AM
Mein Auto: '06 AW 330xi
Is it just your gas gauge?
Does the rest of your cluster work? Is it recording mileage?
When you remove certain fuses (or they blow), the gas gauge behaves as you describe. But in addition to the weird gas gauge, mileage is not stored, ABS, DTC, DSC, EBD, AWD etc.....basically all the safety systems are disabled. Wipers go into safe mode and wipe continuously. Speedo doesn't work. And there are many shadow faults that store in various modules.
Old 07-24-2014, 10:04 AM
Everything else works except the fuel gauge.
