Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 07-20-2014, 06:00 PM
babikes babikes is offline
Mein Auto: 2015 435i convertible
E93 M3 windows
According to the manual, I should be able to open all windows using the remote by holding down the door open button, however it does not work. I read elsewhere that I should first unlock the car, then hold down the door open button - that didn't work either. Any suggestions? If it only works with comfort access, then that's the reason - I don't have it. It's really hot here in FL, and I could really use it.
Old 07-21-2014, 08:33 AM
Prost's Avatar
Prost Prost is offline
Mein Auto: 06 650i, 08 MINI ClubmanS
Not M3 related and I only have an E92...but on my last Z4, only comfort access equipped can open the roof and windows using the fob...I think they are the same
just my 2 cents...
1992 325i Convertible M-Technic II Appearance Package
2002 530i Sport Pkg (Since 7/2015)
2005 X3 3.0i (Lease return in 2008)
2006 330i (Lease return 2009)
2008 Cooper S Clubman (Sold)
2006 650i (sold)
2011 535i M-Sport (ED September 17th, 2011,redeliver on 11/15/2011, sold)
2011 Z4 SDrive35is (ED September 17th, 2011, redeliver on 11/9/2011, Lease return on September 2013)
2013 M3 (ED pickup April 23rd, 2013, redeliver on 6/28/2013)
BMWCCA: 359118
Old 07-23-2014, 05:10 PM
nashvegasr nashvegasr is offline
Mein Auto: 2009 M3 E93
Chk parcel shelf
If the rear parcel shelf is UP and not locked down, pretty sure this feature doesn't work. I've tried to open windows and / or top w/ key a few times, and after it doesn't work, realize that the parcel shelf is UP. Give that a try.
Old 07-23-2014, 06:12 PM
I'm confused. The rear parcel shelf is down when the top is up. There doesn't seem to be a way to put it in an UP position. ???
Old 07-23-2014, 06:16 PM
2011 M3 Convertible windows
Old 07-24-2014, 06:51 AM
JP 99300 JP 99300 is offline
Mein Auto: 2003 E39 M5
I'm pretty sure it only works with comfort access. But there are vendors who sell a remote module kit that will give you this functionality.
Old 07-24-2014, 08:53 AM
Smile
Thanks! Programming with a remote module kit is beyond my meager skills, so I'll see if there's a local shop that can do it. At last resort, I'll check with the dealer, or simply do what I have been doing for the last several years.
Old 07-24-2014, 08:59 AM
Prost's Avatar
Just like what I said, do you have comfort access option? I don't think it will work for the non comfort access bimmer convertible...
2006 650i (sold)
BMWCCA: 359118
Old 07-24-2014, 09:21 AM
Just pull up on the parcel shelf. It moves up and down. Clicks into place.
But yes - if you have comfort access, your windows and top move w/ the key buttons. If not, I think it does not move with the key.
Old 07-24-2014, 10:33 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i; 428 GC; Twin X1's
Mine not only opened the windows, it also dropped the top. And holding the lock button closed the top, then rolled the windows up. I did have Comfort Access.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 09-06-2014, 05:12 PM
Mba///M3 Mba///M3 is offline
Mein Auto: E93 M3
You can have your car coded. I did it on my E93
Old 09-13-2014, 03:37 PM
Thanks. I found a local guy that can probably do it.
