Old 07-24-2014, 12:51 AM
barenickle barenickle is offline
Mein Auto: BMW 318i
Exclamation White Smoke
Please help,
I have been driving 318i 06 plate, now very exhaust with the mechanics even the bmw independent specialist they are just trying to get rid off,
Basically bought the car last year and notice after couple of days about the 02 sensor, had been changed o2 sensor plus engine oil level sensor and all lights were gone but on motorway engine check light went on, did the test they said need the both sensors again, I did changed twice and car started smoke when I pull up the car on 1 and 2nd gear, meanwhile lights was ON, the mechanic said need to replace that electric thingy might it is failing the sensors again and again,
Regarding the smoke he said once 02 sensor changed then no more smoke from exhaust but he failed to be honest, got another option from independent bmw mechanic that lets change the breather chain valve which separate the coolant and oil i think, it is the cheapest way to stop the smoke, after this 2 hours job I was on road but seen the white smoke, contacted the mechanic and got reply from him that 'Change the Engine' awww spend arround £1500 but still not sorted, now not using the car anymore but need to sort this out before i put on sale,
Guys your help would be appriciated.
Din
Old 07-24-2014, 06:52 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Not the easiest problem description to understand (you should avoid highly technical terms such as "electric thingy"), but I'll make a passing comment.
White smoke on a warm day with a fully warm engine is typically a sign of coolant leakage, through a head gasket or the like. If you're sure it's white (and not a light blue, indicative of oil in the exhaust stream), I'd be looking at possible coolant leakage, as opposed to replacing the sensors yet again.
Or, Habemus Papem.
Old 07-24-2014, 06:58 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Hello Din, welcome to Bimmerfest.
It sounds like your coolant is getting into the combustion system. In other words, anti-freeze is being burned inside the cylinders. The anti-freeze is what causes the white smoke, and it will 'poison' your O2 sensors right away. That is why your O2 sensors are going bad, they are being killed by the coolant in the exhaust.
The most common cause of this problem is a defective cylinder head gasket. If the engine is good except for the gasket, the gasket can be changed. You must find out locally what the cost of that will be. First, you must make sure that there is no other damage to the engine. Only a good technician can check for that.
Old 07-24-2014, 07:00 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Or, Habemus Papem.
WTH? (I know what it means.)
Old 07-24-2014, 07:54 AM
Mein Auto: BMW 318i
Thanks very much, I will try to change head gasket, if gasket is ok then any other reason you think ?
Old 07-24-2014, 08:09 AM
Zooks527's Avatar
A small stove and chimney are installed in the Sistene during elections. If an inconclusive vote is taken, the ballots are burned in the stove mixed with straw, which produces black smoke. If a conclusive vote is taken, the ballots alone are burned in the stove, resulting in white smoke. You watch the chimney. If you see black smoke, you wait some more. Once you see white smoke, you gather below the balcony to wait for the announcement.
Old 07-24-2014, 11:18 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Cut me some slack George. There's a stained glass window in St. Christopher Church here in Nashua with my name on it (literally).
I know the whole election process but was too slow to keep up with your wit before a second cup of java this morning. But...good one, habemus Papem it is.
Old 07-24-2014, 11:25 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Replacing a head gasket is a lengthy and expensive repair. Your technician must first verify that the symptoms match the cause. There are a couple definitive tests which can be done which will narrow down the possibilities. One looks for carbon monoxide in the cooling system, another checks to see if one cylinder, or two adjacent cylinders, leak down at an excessive rate when pressurized.
Have you had any codes for any faults other than O2 sensor related? Have you been overheating? Have you been losing coolant without seeing any on the ground?
Old 07-24-2014, 11:42 AM
Zooks527's Avatar
Which beats all hell out of a similarly outfitted granite stone in the churchyard!
That's one thing that ticked my mother off no end when she contributed a window when her church was rebuilt. Instead of doing the "brass plate beneath", the parish put a "Donors" board in the narthex. Years later, she'll still tell you she's convinced they were selling each window multiple times.
Old 07-24-2014, 04:18 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
White Smoke = Sending Signals to the Indians
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 07-25-2014, 12:41 AM
Mein Auto: BMW 318i
Thanks very much for your reply.
Well the electric thingy was Alternator :P
He changed the CVV and also gasket seals for oil leakage, no engine management light on at the moment even engine is not overheating, but the smoke smells like oil burning.
I've heard need to look into the pistons might problem is in there.
regards
Din
Old 07-25-2014, 05:25 AM
DSXMachina's Avatar
Bimmerdex 7.4!
regards
Din
Symptomatic of oil burning. Are you sure the smoke is "white"? Someone needs to properly diagnose this, and it is impossible from a mile away let alone 3000 miles. Find yourself a highly recommended garage and pay them to do it.
Old 07-25-2014, 06:30 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Oil burning? Compression and a leak-down test.
You need to make sure it's definitely oil, though.
Old 07-25-2014, 07:55 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Agreed.
Worn rings-bad valve seats-blown head gasket. All can give exactly the same readings on compression and leak down tests. Still requires further evaluation.
Old 07-25-2014, 02:57 PM
Mein Auto: BMW 318i
Right, now got the point so I'm thinking not to spend more money because it will useless paying for nothing.
Thanks everyone
Cheerx
Old 07-26-2014, 09:15 AM
DSXMachina's Avatar
Bimmerdex 7.4!
This thread has been the Bimmerfest equivalent of a Seinfeld episode.
Old 07-26-2014, 11:24 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
OK! But will they detox après coolant leak fix?
Old 07-26-2014, 11:35 AM
Reregistered User
This is amazing! DSXMachina in stained glass, which we presume predates DSX Machinery. Could it be prophecy?
Old 07-26-2014, 11:50 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Not that there's anything wrong with that.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47° 35' 30.13" E11° 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 07-26-2014, 12:06 PM
Zooks527's Avatar
I shudder at the character I may be playing.
Old 07-26-2014, 02:51 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Hellooo...Newman.
Old 07-26-2014, 02:52 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Not in my experience. The silica plates out on the sensor and when it's dead it's dead.
Old 07-26-2014, 04:41 PM
Reregistered User
There must be aluminum in there....why they don't use a hydrophobic organic film former like steam systems have I'll never know - all that is required is a tiny bit of organic in demineralized water. Shazam! Water cannot contact metals, so they do not corrode. Maybe it's a vibration issue.
Back in the 80's Bell & Gosset stopped warrantying their seals if silicate was used. Makes excellent abrasive grit with certain minerals in water.
Old 07-26-2014, 07:17 PM
Zooks527's Avatar
Hellooo...Newman.
Oh, thank God. I thought I was Elaine.
Old 07-26-2014, 10:40 PM
Dwight_Schrute's Avatar
Dwight_Schrute Dwight_Schrute is offline
I Know Nothing
Mein Auto: '10 E92 335i
And I think we've found our Kramer.
(He's so sane I just blew my mind)
2010 E92 335i
2011 Range Rover Sport Supercharged
1984 Toyota Tercel Wagon 4WD
2007 E93 328i (Sold)
2002 Ford Focus SVT (Sold)
2001 Ford SVT Lightning (Sold)
1992 Ford Taurus SHO (Totaled)
1983 BMX (Totaled... Twice)
bmw e90, breather valve, smoke on start up, white smoke from exhaust
