Old 07-24-2014, 08:46 AM
riso1988 riso1988 is offline
Mein Auto: 2006 BMW 330xi
Koni FSD vs Bilstein for OEM ride/comfort
Hey everyone, I just purchased a 330xi E90 with the sport package. It's got 90k+ and needs a shock/strut replacement (bouncing down the road).
I live in NYC and the roads are as bad as it gets. Therefore, I'm looking to replace the stock sport shocks/struts with comfort as my top priority.
After doing a ton of research, it seems that the best options are the Koni FSDs or the Bilstein touring class combo with the stock (sport) springs. I'm leaning towards the Koni's but the Bilsteins are much more in my price range. I wouldn't mind maintaining the original OEM feel but I'm reading that due to the valving, the Bilstein touring class is firmer than OEM. Given the road conditions, I'm not sure if that is a good idea.
I guess the question is - is the Bilstein touring class much different from the stock sport feel or is it negligible? Should I just go for the Koni FSDs?
Lastly, I'm looking to do this work myself. Should I be buying an install kit ($$) to replace all misc. hardware or would I just be ok replacing the mounts with the struts/shocks?
Old 07-24-2014, 10:10 AM
captainaudio's Avatar
Worlds Foremost Authority
I am very pleased with the Konis on my 07 335i with sport package.
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 07-24-2014, 01:02 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Whelp, plan on getting what you pay for.
Old 07-24-2014, 01:22 PM
I also live in NYC and I think that if the Bilsteins are former than stock they are a very bad idea as the OEMs were too stiff to begin with. The Koni FSDs work very well in NYC roads and I found that both ride and handling improved after I installed them.
BMWCCA
Old 07-24-2014, 02:21 PM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
FSDs give a softer ride than Bilsteins
Old 07-24-2014, 06:48 PM
Zoomie94's Avatar
Zoomie94 Zoomie94 is online now
Mein Auto: 2007 335i E93
I recently had the Konis put on. Based on the recommendation of the installer, no other components were changed out. Really like the way they handle the dips, bumps and potholes vs stock sport suspension. Haven't priced the Bilsteins, but Koni is running a 25% off sale through the summer. I was able to get mine at a pretty reasonable price that way.
2013 E93 335is / Blk/Blk/Al / 6MT / M-Sport / Nav / Cold Wx / CA / Premium / PDC / Recaro ProSPORT / Recaro Performance SPORT (Pics to come)
2007 E93 335i / Blk/Blk/Al / 6MT / Sport / Nav / Cold Wx / CA / Harmon Kardon / Recaro ProSPORT / Recaro Performance SPORT / Koni FSDs (Sold)
1996 E36 328 Cabrio / Blk/Blk/Wood / 5MT / Premium / Butt Warmers (Sold)
Old 07-24-2014, 07:53 PM
thanks everyone, really appreciate the feedback. It seems like the FSDs are the way to go. I guess the question now is whether or not I should replace everything or just the mounts...
Old 07-24-2014, 08:34 PM
Why BMW did not include Koni FSDs as standard equipment on the E9x is something I will never understand as the OEM dampers were garbage.
CA
BMWCCA
Old 07-25-2014, 07:18 AM
You have to be careful with FSDs and oem springs. At the VERY LEAST, you need OEM sport springs.
If you reuse your OEM xDrive springs, you will get a bouncy ride. Any aftermarket lowering spring will pair with the FSDs except extremely low springs, like H&R's Race version.
Start with the struts/shocks and their respective mounts. Then upgrade other parts as you see fit. I have the same car as you and went from coilovers (82k miles), repalced all front arms and bushings at 102k, at 105k did M3 subframe bushings and rear sway bar and adjustable camber links.
Now I have to upgrade the front bushings to something harder as I'm getting some noticeable lift oversteer from the stiffer rear setup
Old 07-25-2014, 09:07 AM
Fdriller - thanks for the info. I guess I didn't realize that although I have the sport package, the springs are non sport as it's awd. I definitely don't want a bouncy ride, that's what I'm trying to eliminate. I guess I should consider other shocks to pair with oem springs or go for a new spring setup.
Old 07-25-2014, 09:30 AM
I have OEM sport springs off 330i you can have for $40.
I'll be in North NJ this weekend if you want to pick up
Old 07-25-2014, 10:54 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Seems like a killer deal there!
