Old 07-24-2014, 10:53 AM
makem-shep makem-shep is offline
driveITlikeUstoleIT
Mein Auto: bmw e46 325
E92 325i intermittent humming noise HELP!
Hi guys, ok so I bought a new e92 325i m sport 2008 last week. All is great except one little thing. Like the title says there is a strange intermittent electrical humming noise which I can hear while idle also while driving. It comes and goes. I had car out today and no noise until I drove 10 mile then it started, came on for about 5mins then disappeared, then I drove another 10 mile (car hadn't been turned off) to home and noise had returned, it's driving me nuts. Mainly because I have garentee with car which runs out in 2 weeks so want to find what it is incase it bad news. I will try and attach a video, it's defo not the a/c unit as had that issue on my e90
Please listen carefully as it is really faint (speaker next to ear) but loud enough to annoy me, hope yous can help. I will be hugely grateful,
Old 07-27-2014, 09:27 AM
antimatt3r335 antimatt3r335 is offline
Mein Auto: 08 335xi JB4
I am currently looking at a 08 335i that is doing this same exact thing wtf is it
Old 07-27-2014, 09:35 AM
jackyfrombmauto jackyfrombmauto is offline
Mein Auto:
I cant hear anything, this engine only facing with few rare problem with vacuum system. Try to start the engine and let the engine run at idle and then remove the oil filling cap, if the humming voice gone or you cant open the oil filling cap, it mean your ventilation valve is bad.
Old 07-27-2014, 09:37 AM
I can def. hear it, it does not start until 5 seconds into the video over on the left side of the motor its almost like a beeping type hum with an almost medium to high pitch/tone beeping about once a second
you can clearly hear it beep a few times between five and nine seconds on the video
Old 07-27-2014, 09:56 AM
Mein Auto:
Oh, i think that is the problem, ventilation valve. It located on the valve cover, check your country whether they do sell the repair kit of not, malaysia here we dont have repair kit, normally we need to change the whole new valve cover, expensive.
Old 07-27-2014, 10:13 AM
is there two vaccum lines and one electrical cord going into a box on this thing your talking about? n the 335 i was looking at it almost sounded like the noise was coming from this box on the left side of the head cover
Old 07-27-2014, 10:17 AM
Mein Auto:
Not so sure what you mean on the first question, but the head cover yes is the sound coming out from there, definitely. Just when the beep humming sound coming out again, just remove the oil filling cap, if the beep sound is gone, means the ventilation valve bad.
Old 07-27-2014, 10:18 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Beware! Beware! Sounds like countdown to Self-Destruct!
Old 07-27-2014, 02:46 PM
driveITlikeUstoleIT
Really appreciate your replys guys, I will take your advise on board when it goes in to get looked at hopefully this week,called into bmw at weekend and suprise suprise couldn't get noise to reproduce :@ but they heard it a little and said didn't know and would need noise to be on all time to locate it. But....since then I've noticed, when idle and revs at 1000-1500rpm is exactly when it appears and assume also while driving (but engine noise drowns it out) and gets worse and more frequent as engine gets hotter. I'm thinking maybe coolant/pump system related. Excuse the long msg, as I stressed earlier, need urgent diagnosis as car still under guarantee, cheers for the help
Old 07-27-2014, 02:52 PM
driveITlikeUstoleIT
There's a new bit better vid i took earlier, clearly hear it much more inside the car, comes from front passenger side (uk)
Old 07-27-2014, 06:31 PM
Mein Auto:
Is really nothing to do with your coolant pump, so sorry have to disagree with you because i met this problem and solve it, i am a mechanic. If you not confident on what i saying, just do the diagnose like what i suggested. Just open the OIL FILLING CAP while the beep sound is present, if the beep sound is gone, that mean your ventilation valve is bad. I will send a picture of that valve later.
Old 07-27-2014, 09:34 PM
Mein Auto:
TClick image for larger version
You notice there is a round thongs at the left down side, that is the one is bad
Old 07-28-2014, 12:01 AM
driveITlikeUstoleIT
No that's great. I appreciate your help. I'm not clued up with cars so my coolant theory is only a guess, I will inform the garage of your advice. Do you know if it's a costly fix?? Just car is still under garentee so if it is the car can go back (reluctantly)
Old 07-28-2014, 12:18 AM
driveITlikeUstoleIT
Ps, is it called the crank case valve?
Old 07-28-2014, 12:20 AM
Mein Auto:
Erm, actually i from malaysia, malaysia price here is around 1-2k ringgit, i not sure about the price because my boss is the one who decide. We never repair the cover because malaysia here never sell the repair kit, we usually replace the new cover.
Old 07-28-2014, 12:24 AM
Mein Auto:
Yes, that is the one. Your engine is n52b30 the cylinder head is different than n52b25. If the b25 crank case valve is bad, we can change the valve under the intake manifold, b30 the crankcase valve is build in with the head cover, but cylinder head is better you wont get the ticking sound when morning you start.
Old 07-28-2014, 01:20 AM
driveITlikeUstoleIT
This helps a lot thank you very much. I will keep you updated
Old 07-28-2014, 03:07 AM
driveITlikeUstoleIT
Just had garage on the phone, my macanic (15yr at bmw) said it's not the ventilation valve as that would mean a constant hum/beep whereas my videos Cleary show it only appears when I rev the engine to 1000rpm, he seems to think it is the throttle air valve or something,!! And is normal but is unfortunate that you can hear it on some models but can't on others. Tbh I'd rather it of been something that can be sorted out, but at least it's nothing to worry about and car runs fantastic.
Old 07-28-2014, 09:04 AM
Mein Auto:
Great to hear that, i am not perfect just share with you what i had been experience with this problem. If you got any chance solve the beep humming sound problem with another solution, please let me know.
Old 07-28-2014, 10:18 AM
driveITlikeUstoleIT
I most certainly will my friend, and thanks again for your help, just had car out for good drive tonight (45 mins) hard, and noise was on until car got to running temp then couldn't get it to do it whatsoever arghhh, but that's good I suppose, I read somewhere to take cd changer out which is wierd (which I did when car got hot) so il leave that out for few days see what happend
Old 07-31-2014, 02:00 PM
driveITlikeUstoleIT
Just a quick update! Bloody noise is gettin worse, still disappears when engine is hot but totally annoying me now, I'm preying someone has had this noise and solved this
Old 07-31-2014, 02:07 PM
driveITlikeUstoleIT
Old 07-31-2014, 03:15 PM
driveITlikeUstoleIT
Sorry my bad..... There it is :/
Old 07-31-2014, 03:27 PM
driveITlikeUstoleIT
And the other one lol sorry
