Old 07-24-2014, 07:43 PM
dsbarr dsbarr is offline
Mein Auto: '06 BMW 330i
Oil Level
Problem Solved Thank You
2006 BMW 330i~Barrique Red~Sports, Prem, Cold Weather Package's ~ 6-spd Steptronic ~ Logic 7
Old 07-24-2014, 07:56 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
"OK" means you are good. Don't add oil unless it says to add.
Old 07-24-2014, 07:57 PM
AzNMpower32's Avatar
Tar Heel Faithful
That picture shows it at full......
fine with me. thank you!
Old 07-24-2014, 07:59 PM
Yes but the picture is not my car. I was unable to take a picture. The line in the picture is at max. Mine is a little before max
Old 07-24-2014, 08:11 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
You're still OK. The scale represents a single quart. It will tell you when you need to add a quart.
But if it makes you feel better add a few ounces then wait to check the level indicator again ten minutes later and repeat until it shows full.
LOVE your car, pretty much the same as mine except mine is just a regular Barrique Red 2006 325i manual.
Old 07-24-2014, 08:18 PM
Ill hold off for now I just wanted to make sure. And thank you! I really like that color. I don't see it on many other BMW's either which I take as a plus.
Old 07-25-2014, 03:37 AM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
One notch equals 1/4 of a quart low. You can drive until your next oil change and it will not hurt your car.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
Old 07-25-2014, 06:59 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
off-topic, but how did you get an oil temp gauge in a 330 4-door???
Old 07-25-2014, 07:09 AM
Mein Auto: '06 AW 330xi
You can't. Maybe in the hidden menu but there's no factory option for an oil temp gauge
Old 07-25-2014, 11:30 PM
sptt144's Avatar
es. It's the gauge check through the cruise control stock. It definitely reads a little different than from the idrive check display and can throw folks off although it's telling you the same thing.
Old 07-27-2014, 10:26 AM
jackyfrombmauto jackyfrombmauto is offline
Mein Auto:
Actually i face with this problem, that the customer say the oil level is in the middle so they add 1little and the gauge still showing the same, so he decided to add another one more little, still the same. When i run through with icom, i saw a service function call adaptation value, it stated it will clear all the value of the sensor, so i give it a try and it work, the gauge work normal again.
