what year is your car? im not sure if it is the same on the e90's but the e92 LCI models have about 8mm less space that the pre-LCI's.
I have an LCI e92 and run those exact sizes and offsets with 265/235 tires. No rubbing. I could probably even afford to put 10mm spacers on for a "stanced" look.
Figure out your plan for lowering first. Let the suspension settle for 2 weeks after install, then get an alignment. Then you can install spacers
When you lower the car, the car naturally gains negative camber. It can be dialed back somewhat with the factory arms but especially in the front with no factory camber adjustment, you will have more negative camber.
This will bring the top of the wheel inward and make it appear to be more "tucked." You can add a larger spacer so the wheel sits more flush after lowering. If you do it before, you may see an additional gap after lowering.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
