V1 Savvy Install in wife's X1 - Bimmerfest - BMW Forums
Old 07-30-2014, 04:36 PM
KingJimmyB's Avatar
KingJimmyB KingJimmyB is offline
@KingJimmyB
Mein Auto: BMWs!
I am driving my wife's 2014 X1 until my 2015 X5d arrives. I have wanted to install her V1 cleanly without any need to splice wires in the OEM wiring at all! The Savvy is an alternative to splicing and creates a very clean finish. Took 20 mins total. Used the rubber door moulding and headliner with an id card to hide the V1's wiring in the grooves seamlessly. There is a small access door next to the ODB (sic) where I stored all of the wiring harness/connections for the Savvy and V1 power. Drill a small hole to slide the wire from the Savvy on the top of the access door to hide all and keep a clean finish. Powered on the X and let the Savvy have it's 30 second 1st use cycle complete and walla the V1 is on. Cycled the X several times on and off to check for any issues and road tested for any wire vibrations. All good. Just as an FYI the V1 cycles on about 3 seconds after pushing the start button to power up the X's electronics. That totally normal per the instructions. Hope this helps someone else. Click image for larger version
-2015 X5 35d xDrive
-2015 M4
-2015 Chevy Silverado HD
-2014 X1 28 xDrive (retired)
-2013 328i (retired)
-2011 535i (retired)
-2008 X5 4.8i (ehhhh buy back)
-2006 325i (retired)
Old 08-29-2014, 01:00 PM
BMWBig6 BMWBig6 is offline
Mein Auto: BMW X1 sDrive28i M Sport
Thanks for sharing. Do you use the Auto Start/Stop (ASS) feature (or Eco Pro mode)? I'm wondering if V1's Brownout-Booster is needed to maintain voltage at stoplights so it doesn't always reboot and beep every time the engine restarts when the light turns green.
2015 BMW X1 sDrive28i M Sport
2015 Porsche Boxster GTS
2011 Ford F-150 Limited
Retired: 09 Audi A4 S-Line Avant | 08 Audi TT S-Line / 03 Ford SVT Lightning / 01 Ford SVT Lightning / 93 BMW 740iL / 90 BMW 535iM / 86 Porsche 944 Turbo / 83 Porsche 944
Old 09-02-2014, 02:08 PM
KingJimmyB's Avatar
@KingJimmyB
Mein Auto: BMWs!
We don't use that function but it does turn it on and off as I just tried it.
-2015 X5 35d xDrive
-2015 M4
Old 09-02-2014, 02:28 PM
Thanks! I may try the in-line Brownout Booster and will report back.
Old 09-02-2014, 02:31 PM
KingJimmyB's Avatar
@KingJimmyB
Mein Auto: BMWs!
Please I'm interested to know if that does work. I took delivery of my X5 last week and used an invisblend cord to tap into my rear view and it works like a charm. Not an option for my wife's X1 as it's too late to return the Savvy or I would have used it as well.
-2015 X5 35d xDrive
-2015 M4
Old 09-04-2014, 05:31 PM
Since I haven't personally tested this combination yet, I contacted V1 and they quickly responded that the Savvy and Brownout Booster are not mutually exclusive and many customers combine them together.
Old 09-04-2014, 07:15 PM
gcrofton gcrofton is offline
taxpro
Mein Auto: BMW 540iA and X1 xDrive35
What is V1?
Old 09-04-2014, 10:27 PM
Pat_X5's Avatar
Pat_X5 Pat_X5 is offline
Mein Auto: '14 F10 +'16 LR Discovery
Valentine 1 = radar detector
Price you pay for one new = price of speeding ticket you save + point on your record = very well worth it.
V1 has saved my behind many times over!
