E34 (1989 - 1995)
Old 07-31-2014, 05:27 PM
CJ74753 CJ74753 is offline
Location: High Point / Thomasville area of North Carolina
Mein Auto: 91 BMW 525i
Question 91 525i Electrical troubleshooting splice location X451
Has anyone managed to find the electrical troubleshooting manual with the splice locations listed in it for the 91 model? http://wedophones.com/BMWManualsLead.htm has the manual but like with every other version I can find section 8000 is missing out of it. I'm trying to locate splice X451(seems rather odd though because X451 is not even listed in the component location chart), it is the main split off of fuse 18. Perhaps I'm overlooking something, so hopefully someone with more experience can lead me in the right direction here with trying to track down my little electrical demon.
Old 07-31-2014, 06:05 PM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, E30, E24
Try the ETM posted at jokensy.com -- it's for later models but the manual is searchable.
I see X451 in the harness on the floor in front of the auxiliary fuse/relay box under the rear seat. I'd hunt in that area, looking for white/violet striped wires.
Old 07-31-2014, 07:09 PM
Thumbs up Thank you!
Thank you for noticing that. I had flipped through it but obviously had missed this. Seems that they renumbered some of the splices but they all seem to correspond to one another. Great find, thanks again. Now hopefully I can track down my short, I know something is up with my speakers also as they all work they just won't all play (at least that was the case when the radio did work when it just intermittently blew fuses.
Old 08-03-2014, 12:04 PM
Just a note, the 91 ETM seems to be incorrect from what I can tell. 91 ETM shows fuse 18 also powers the rear cigar lighter, 92 ETM shows that fuse 26 powers that circuit and mine (built 10/1990) is on fuse 26. So hopefully this will help someone later on down the road.
Old 08-03-2014, 04:07 PM
I've spotted other errors in the ETMs. Good catch on this one.
Old 08-03-2014, 08:10 PM
Can anyone verify (info I found here)that pin 16 on the radio harness (white wire) supplies 12vdc to power on amp when the radio is powered on? Mine appears to be supplying none if I'm testing it correctly. I got my radio back to working but there is NO sound from the speakers which is a new problem to me.
Old 08-03-2014, 08:47 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Yes, that is the wire that turns on the amp, and according to that link you listed after i read the whole thing i noticed that the poster put 12v to it and the amp power on, you could try that and see how it works for you.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 08-03-2014, 09:03 PM
Well I jumped mine out and my radio plays till I remove the jumper wire (measured the voltage on the white wire and it has no power being supplied). I'm guessing my radio has been going out ever since I purchased the car, the majority of the speakers never played even though they were good then it started randomly popping fuses. So I'm guessing its off to the salvage yard to see if I can't find a used one, then maybe my 6-disc cd changer will also start working again.
Old 08-03-2014, 09:15 PM
Nothin like an E34
There is a 525 in Charlotte in a JY and also two in Durham, and one in Raleigh, all the E34s i know of West of me.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 08-06-2014, 06:34 PM
Factory radios lifespan
Well I seem to have horrible luck with electronics. I went to the salvage yard and pulled a radio out of a 94 3 series, had to call 3 different dealerships to find one that could give me the radio code only to find that this one will just barely play out of the front speakers with the volume control maxed out. My old one would only play on the rear...so are these factory radios bad about going out at this age?
Short....I still have to find this pain in my butt, while messing with the radio my circuit breaker started tripping and just as I thought I was going to track it down the short stopped again.
Old 08-09-2014, 09:23 PM
Lightbulb Success
Well I found my intermittent short to ground on my radio circuit, it was in my glove box light wiring...appears that the power wire got pinched between the dash and the upper metal glove-box bracket. I connected an older Clarion head unit up and all I can say is wow, I've never heard the car play this many speakers and it sounds excellent for factory speakers.
