Old 08-01-2014, 09:01 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Weep hole leak
Well at 148k on the clock the weep hole leak finally got to me. But with a BMW tech doing work on side and aga coolant pipe getting it done this weekend. Last weekend it was struts control arms and alternator bracket. I would say at 148 those failures could have been a lot sooner.
Old 08-01-2014, 10:07 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
I'd say you're doing pretty good.. my alt bracket was leaking at 68,000 miles. At 148k, the repairs are justified.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 08-02-2014, 07:43 AM
Busarider Busarider is offline
Mein Auto: 745LI
How much is he charging for the AGA replacement?
Old 08-02-2014, 08:17 AM
825 for labor 145 of that is for parts like valley pan intake gaskets. I had to buy pipe from aga for 600. He gets the other parts at discount.
Old 08-04-2014, 08:32 PM
Mein Auto: 745LI
I just noticed some "green" stuff next to the "y" pipe passenger side, not sure where it's coming from and I fear the worst
Old 08-05-2014, 07:08 AM
meangreen94z meangreen94z is offline
Mein Auto: 2004 BMW 745i sport
Either the vent coolant Y-hose(not to be confused with the secondary air y-pipe) that runs between the cylinder heads to the expansion tank, or the valley pan. The coolant weep hole is on the front timing cover, next to the water pump.
Old 08-05-2014, 07:56 AM
If its not your valley pan or weep hole I would get them done anyway. Since last winter I chased coolant leaks first it was hose from reservoir to cylinder heads then expansion tank then finally weep hole pipe. I should if went straight to the pipe and save time and money.
Old 08-05-2014, 09:17 AM
Mein Auto: 745LI
It is possible that the leak could be from the vent coolant hose cause i don't see anything from the weep hole.
Is there a way to check the vent hose visually?
Old 08-05-2014, 10:32 AM
Its underneath the front of the intake manifold. If you are having a hard time seeing it, remove the throttle air duct, and then the throttle(4 10mm bolts and a connector). With the throttle removed you can easily see and replace the coolant vent y-hose. You can also see the valley pan for inspection.
Old 08-05-2014, 11:10 AM
Mein Auto: 745LI
Is it # 10 on the diagram?
http://www.realoem.com/bmw/showparts...72&hg=17&fg=30
Old 09-04-2014, 11:47 AM
Mein Auto: 745LI
Thanks Meangreen94z, it worked like a charm just like you mentioned. Was easy to replace, the "Y" joint had gone hard and cracked and was leaking.
