Old 08-03-2014, 06:22 AM
sandeepkarna sandeepkarna is offline
335ier...
Mein Auto: 335i 2009 AT sports model
Question Changed Rear Brake Pads and Rotors
Hi,
i have changed my rear brake pads and rotors with a indy who charged me 500$ .Indy used textar brake pads and zimmerman rotors are these good for 2009 335i sedan sports pckg?
Also whn i reset the service it showing now 15000mi with new pads on .So is this milege on new pads is usual ? please advice.
Old 08-03-2014, 10:11 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
You're good. Those are great pads and good rotors. You should be able to change just your pads in about 10k miles if you are concerned.
Old 08-04-2014, 08:41 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
15k is the std reset level...don't need to worry about that sensors will tell you when is the time to change them.. Rears usually last 30-40k sometimes even 60kmiles - depends how you drive. Front goes about half of the rear.
Old 08-04-2014, 08:43 AM
Mein Auto: '06 AW 330xi
Textar used to be the OEM supplier for BMW brake pads. Not sure if that's the case anymore.
