Old 08-03-2014, 12:39 PM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
Spark plug Q
Do my OEM spark plugs require a special socket for removal? I saw a couple of videos on utube , and they mentioned a STAR shaped socket for the plug removal, the plug had a kind of star shape to it. Definitely not your standard type plug. I did a search for plugs, and everything I found for my model car, looks like a standard socket is all that is needed for installation.
Rob
Old 08-03-2014, 01:14 PM
grijo grijo is offline
Mein Auto: 2013 BMW 328i Coupe
Originally Posted by Bigrob126 View Post
Do my OEM spark plugs require a special socket for removal? I saw a couple of videos on utube , and they mentioned a STAR shaped socket for the plug removal? I did a search for plugs, and everything I found for my model car, looks like a standard socket is all that is needed for installation.
I believe it is a regular metric thin wall socket.
2013 BMW 328i
2008 Honda S2000
1972 MB 250C
Old 08-03-2014, 01:23 PM
Bigrob126's Avatar
I was just looking some more and the socket I find does look like a standard socket...just a 12 point style...thanks!
Rob
Old 08-04-2014, 01:54 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Here you go:
http://www.burgertuning.com/N54_BMW_...t_adapter.html
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 08-04-2014, 07:29 AM
DSXMachina's Avatar
Bimmerdex 7.4!
BMW Plug Socket
Here are a couple BMW sparkplug sockets. The one on the right is one I made the first time I encountered the plugs. I took a regular socket and ground it on a bench grinder until it fit into the plug recess. The one on the left is a socket I bought years later.
Old 08-04-2014, 07:39 AM
Bigrob126's Avatar
Thanks, so it IS just a regular 12 pt 14mm thin walled socket....no prob!
Rob
Old 08-04-2014, 09:41 AM
Phil325i's Avatar
Yes, but bear in mind the Burger one has a magnet so you don't end up with the plug loose at the bottom of the access 'tunnel'. The plugs are deep inside the head, and if you don't use a magnetic socket you'll need something else to draw it out with...
Old 08-04-2014, 11:31 AM
Bigrob126's Avatar
Got it! Grazie!
Ya know....I notice every socket I have seen, including this one from burger, only mentions the turbocharged models of BMW. I have a non turbo 328i. This will fit, yes?
Rob
Old 08-04-2014, 04:55 PM
ZBMAN ZBMAN is offline
Mein Auto: 328i XDrive 2009
Just did my 328i plugs. I used a regular deep well socket and a piece I duct tape. Worked fine.
