Old 08-04-2014, 09:44 PM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
Michelin Latitude Tour HP 255/55-18 for cheap
I just bought a set of 18s to use as winter wheels. They currently have some very good tires on with plenty of life.
I got a good deal on the wheels and I want to share it with someone: I'm selling all 4 tires for $150. Yes you read it right: ALL FOUR TIRES FOR A TOTAL OF HUNDRED AND FIFTY DOLLARS.
The tires are Michelin Latitude Tour HP run flat. The specs are 255/55-18 109H. Tires are currently on the rims and buyer pays for removal but I can deliver them to buyer if at reasonable distance. I'm in San Diego, CA.
Pictures attached.
ID:	456633   Click image for larger version
ID:	456634   Click image for larger version
ID:	456635   Click image for larger version
Old 08-05-2014, 05:38 AM
rpoitras rpoitras is offline
Mein Auto: 2010 BMW X5
Any chance you feel like taking a trip to NY?
Really, that's great of you to share the savings. Wish I was closer to you. My next set won't be run-flats but for that price I'd live with them a a bit longer, haha.
Old 08-05-2014, 06:16 AM
PAX5 PAX5 is offline
Freude am Fahren
Mein Auto: X5 50i
Now you just need those pre 2010 TPMS's ... $100 shipping included!
Name:	BMW OE TPMS(1).jpg
PAX5
BMWCCA #20645
Old 08-05-2014, 07:23 AM
Eheheh... Actually the wheels have the TPMS so I should be good. I'll have to try them out and ensure they work.
Old 08-05-2014, 03:28 PM
Just as an FIY since I looked this up for someone else: the cost of shipping all 4 tires to New York is roughly $250-$260 FOR ALL FOUR (to be confirmed based on buyer ZIP code). Shipment will be via LTL provider (that's less-then-truckload): I'll drop off the tires at a local carrier depo and you pick it up at the local carrier depo. This can be done throughout the country.
If you want a quote to your location go to: http://www.freightcenter.com/QuickQuote.aspx
My ZIP code is 92057; in location type select Terminal to both me and you. According to tirerack (http://www.tirerack.com/tires/tires....ude+Tour+HP+ZP), the weight per tire is 42lbs and the measures are 30x30x11. For freight class use the lookup tool to find tires ("Automotive" - "Wheels or Tires" - "Tires, pneumatic")
Old 08-06-2014, 10:06 AM
ard ard is offline
Resident Curmudgeon
^^ OMG. UPS and FedEx ground band them together and charge $25 a tire, last time I checked. (Although I had a fedex contract)
http://www.ups.com/content/us/en/res...lar.html#Tires
Also, greyhound will ship for 2 tires strapped together, 45 lbs, from CA to NJ for $65: http://www.shipgreyhound.com/e/SitePages/gpxStep1.aspx
I purchased a one piece rollbar for the Pcar from Maine- out here to Cali for $140.
Old 08-11-2014, 01:43 PM
sankom sankom is offline
Mein Auto: NJ
Tires changed
This is what I did for my tires - 2013 X5 35d
- I had Bridgestone H/L 400 RFTs (i guess). Changed them when 1/8 thread was left (22K miles). Stored them in my shed
- Installed Bridgestone non RFT Ecopia 422 for $846 installed
- Order Spare Tire kit for $380 online
At lease end I will decide, if I buy the car, I will continue using Ecopia 422 and sell the RFTs to someone on this forum who will be stuck at the same situation needing RFTs to return to lease. I am in Central NJ
If I decided to return, I can put RFT back and return and see what I can do with the non-RFTs.
But a decision now can save lots, unless one sticks with RFT till the end ...
Old 08-12-2014, 04:39 PM
edbernales edbernales is offline
Mein Auto:
Old 08-12-2014, 04:43 PM
Mein Auto:
Originally Posted by edbernales View Post
I'm interested in your Michelin run flats...
Old 08-12-2014, 06:22 PM
Mein Auto:
Pls PM me @ 9515915808. I'm interested. I'm in Riverside county. I can pick it up in SanDo.
Old 08-12-2014, 07:26 PM
Ok, I've been asked about thread dept: I don't have a gauge so here's the penny trick.
By the way the price is really take it or leave it: $150 + buyer pays to remove the tires. If they don't sell for that I keep 'em and use them.
I've measure all tires in spots:
Here's the date stamp of all 4 tires:
Here's the rim: if you like them and want to trade them (provided I like yours and yours, they are not aftermarket nor repainted nor scratch and come with TPMS compatible with my car) it's a flat $150
