Old 08-06-2014, 08:43 AM
chuckwww chuckwww is offline
Mein Auto: BMW 328xi (2007)
Bluetooth module is all I need?
Just bought a 2007 328xi. It has the "professional" stock sound system and controls for phone on the wheel. It doesn't seem to have Bluetooth at all though, basically nothing happens if I hold down the phone button.
Is it a good assumption that I can just purchase the BT module off of eBay and plug it in somewhere and be good to go? Or is it more involved than that?
Chuck
Old 08-06-2014, 10:11 AM
Porando Porando is online now
Mein Auto: 2011 335i, 2004 X5 4.4L
Need to check if it is pre-wired. If so you will need to code it..
http://www.e90post.com/forums/showthread.php?t=3540
Old 08-06-2014, 11:49 AM
bmwali bmwali is offline
Mein Auto: 328xi
Smile
May I suggest a simple after market thing. This is as simple as a build in system. Just plug it in once you start your car, it connects to your phone automatically( I have an galaxy s4 and BMW 328xi-2007).
http://www.amazon.com/Kinivo-BTC450-.../dp/B009NLTW60
I had issues with this one last year, but with the latest OS update on Galaxy s4, it works fine now and it is awesome.
Old 08-06-2014, 01:16 PM
I really like the idea of an aftermarket solution like that. I'm finding the non-premium sound kind of lacking and trying to brainstorm ideas about that, so the notion that this product might work with some aftermarket head unit is attractive as well.
Thanks very much!
Chuck
Old 08-06-2014, 01:20 PM
Mein Auto: '06 AW 330xi
Have you tried pairing a phone to your car?
The button won't do anything if there is no phone paired.
Go into your device setting on your phone and go into the bluetooth menu. Available bluetooth devices will pop up there.
If there is a button for the phone, I imagine it's bluetooth equipped. There are other multifunction button clusters available from BMW that do not have the phone button so I can't image they would install the button without the functionality.
Old 08-06-2014, 05:08 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
For stereo upgrades go here
http://www.e90post.com/forums/forumdisplay.php?f=27
and read this
http://www.e90post.com/forums/showthread.php?t=641323
And these
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/showthread.php?t=343673
http://www.e90post.com/forums/showthread.php?t=138949
http://www.e90post.com/forums/attach...1&d=1209780605
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/
http://www.e90post.com/forums/attach...1&d=1209780865
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...4&d=1278871872
A Dension Gateway 500s will give you bluetooth phone , Music streaming and USB/Ipod.
If you want to go with the stock Head Unit or Idrive.
If you want to change head units that can be done to but there are side effects.
There is a new dynavin double din that has been advertized here and on the e90poast thread.
Its jammed packed with features but is not the best way to increase sound quality by itself.
http://www.e90post.com/forums/showthread.php?t=1016187
Old 08-06-2014, 06:42 PM
Thanks -- I get no option to pair when my phone is polling for Bluetooth hosts, so I'm assuming there isn't anything there. If I hold that phone button down nothing happens and on the "MENU" button there's no indication of BT option, so that's another indication there is nothing happening there.
Old 08-06-2014, 08:10 PM
If you have bluetooth phone when you touch menu.
There will be a icon of an old timey phone in the list along
with cd and radio.
If you read the third link down in the list I gave you there is
a pdf document describing the entertainment and shows where
the bluetooth module is in the car.
Also using one of the BMW vin decoders found online will tell you
what options are installed in your car.
Almost all aftermarket head units now have phone and bluetooth music streaming built in.
Old 08-06-2014, 08:13 PM
with cd and radio.
If you want to buy an OEM setup it will require some programming
and maybe some hardware.
http://www.e90post.com/forums/showthread.php?t=85149
bluetooth audio, module
