Old 08-06-2014, 01:49 PM
montourey montourey is offline
Mein Auto: 745Li
2005 745Li - secondary air system bank 2
I'm a new member to this site I hope I'm doing this right. My check engine light came on and I had a friend check to find out the code, it came back PO492 which I'm told is "secondary air system bank 2. Does anyone know what needs to be done? Is this something I should only have the dealership fix or just a good mechanic. The check engine light has gone off now but I don't know what to do. Thanks for any help.
Old 08-06-2014, 02:43 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Unless the code pops up again i wouldn't worry about it.
Our cars have loads of sensors and every now and again it can throw an error.
My BMW ACS7
Old 08-06-2014, 02:59 PM
cjennjr cjennjr is offline
Mein Auto: 2002 BMW 745i
My '02 745i has been throwing that code for years. I don't really worry about it because it has nothing to do with the operation of the engine. Eventually I may fix the issue (carbon buildup or secondary air control valves gone bad), but right now I'm not sweating it...
Black Beauty
Old 09-11-2014, 01:21 PM
Mein Auto: 745Li
The check engine light has come and gone and is back again, and I'm told that the car has blue smoke from the exhaust. Any idea what this might be? The blue smoke from exhaust was after I had driven a distance of about 80 highway miles. Got a good mechanic but wonder if this is a "dealership only issue"? 2005 745Li w/ about 87,000 miles, please help.
Old 09-11-2014, 01:58 PM
paco438 paco438 is offline
Mein Auto:
It's your valve seals... I just had mine's replaced. For the same reason. I didn't go to dealer. I would just find a shop that works on bmw
Old 09-11-2014, 03:09 PM
fratan fratan is offline
Mein Auto: 2006 750i
The blue smoke is valve stem seals and while idling the oil is trickling on the heads causing carbon build up. The carbon build up won't allow enough air from the secondary air system to reach the exhaust manifold so the p0491 code pops up. This doesn't effect the performance but a nuisance for inspections.
2006 750 I
Old 09-11-2014, 03:36 PM
Mein Auto: 745Li
Is this a costly repair?
Old 09-11-2014, 04:56 PM
Mein Auto:
The valve seals job cost about 1300-1500
Old 09-13-2014, 06:39 PM
Hu$tla_Rob$ Hu$tla_Rob$ is offline
818 - SFV - SoCal
Mein Auto: BMW E66 745LI
Smile
Mine has the same code and blue smoke all I did was change the oil to mobile 1 synthetic 0w-40 got 8 quarts and a bottle of oils leak sealant and also put a valve cleaner in the fuel system and no more white smoke.
Old 09-13-2014, 07:08 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
^^^ sounds like a liquid band aid. Can't begin to imagine the mess you're creating in your engine.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 09-16-2014, 08:50 AM
People tell me that they use different weight oils in the engine. Some of the oil cleaners should be removed after a few hundred miles. I have always used 5w 30 in my n62. I'm curious to know if anyone has tried 10w 30 ?
2006 750 I
