Old 08-06-2014, 10:43 PM
Rg21044 Rg21044 is offline
Mein Auto: 335i coupe, jeep
Jb4 install help
Is there anyone who would be willing and able to help me with a jb4 install. I'm between Baltimore and DC and would be willing to drive to you (anywhere in MD, Northern VA, Delaware or Central PA). I can bring beers...or scotch if that's your thing...as a token of my appreciation. Thanks.
2007 BMW E92 335i Coupe
Old 08-07-2014, 08:21 AM
f1snob f1snob is offline
Mein Auto: 2009 335i Xdrive Coupe
Rg, I am not near you and can't help, but what do you need help with? The instructions on Burgers site are pretty good. n54tech.com is a great source as well. There are youtube videos too.
Although I have replaced clutches, engines and put new stereo gear in nearly every car I have owned over the last 35 years, I never did anything like modifying an ECU. I took my time, followed the instructions and found the process pretty easy. Watch the plugs when plugging it in, but they are designed to only go in one way. If you have to force it, it may be wrong.
The only problem I ran into was with the USB cable. You have to lock the car and wait for the ECU to shut down before install and don't open the doors until it's all hooked up. But at the same time you have to get under the glove compartment to pull the cable through. How do you do that without opening the door?
I had the ECU out, ran the cable through the hole as far as it would go, hooked up the JB4 then opened the door, pulled what I could, back under the hood and pushed the cable some more, pulled more in the car and eventually got it. I put everything back together and with heart pounding and hands shaking it started immediately and everything worked perfect. All I've run is MAP 1 on my mostly stock car, but it's been great and works perfect.
Best wishes and let us know how it goes.
2009 335i xDrive Coupe Space Gray
Premium, cold weather and sport packages
Steptronic, JB4, DCI
JB4 DCI
Old 08-07-2014, 08:30 AM
Thanks for the reply. I am not mechanically inclined at all. We'll see what happens. Maybe someone will be able to help in person.
