E34 (1989 - 1995)
Old 08-10-2014, 09:14 AM
ubersnarf ubersnarf is offline
Mein Auto: 1994 540i A
Slight "eccentric" brake pulse when coming to complete stop
Hey guys,
So I've done a lot of work on the beast as of late. Including rebuilding the entire front suspension, control arms, bushings, tie rods, new shocks/struts, mounts and springs all around. I've done the brakes as well with new pads, new OEM rotors and a brake fluid flush. I left the calipers as they were, old. Pelican parts didn't have rebuild kits in stock when I did the brakes so I had to let that go. Overall the car drives fantastic.
But it still have this issue I can't figure out.
But when I come to stop I get a slight pulse in the brakes, it's almost "eccentric" as the car is stopping and it is really only noticeable at light stopping speed. If you stand on the brakes it hard you don't notice it. It's driving me crazy as there isn't much left to replace that I haven't already done.
Could this be due to me not rebuilding the brake calipers? The caliper piston is possibly binding? Or is this possibly the ABS unit? I don't think it's the wheal bearings but you never know. I keep leaning towards caliper rebuild time, I'm curious if any one else has experienced this.
As always any input is appreciated. I would love for this car to come to a clean stop.
Cheers,
Rob
Rob T
Licensed troubleshooter...
Current toys...
1998 Tacoma XtraCab 4x4 (aka the Goat)
1994 e34 540A (Bavarian Falcon)
Old 08-10-2014, 12:10 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
The next logical step would be to check wheel and tire runout.
Good food, good people, good times.
Old 08-11-2014, 07:50 AM
That's a good point. I'm going to looking into that. I don't have a dial indicator at the moment but I did find online a " wood block method " to check tire wheel run out. Not the most precise way to check things but it could give me an idea. Thoughts?
My next question would be if my wheel run out is out of tolerance, what is the cause?
Wheel bearings?
Rob T
Current toys...
Old 08-11-2014, 07:55 AM
But the tires are new and have less than 1000 miles on them...
Rob T
Current toys...
Old 08-18-2014, 12:07 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Shake your wheel while in the air. Check for play..
I know one in a million you have to remount the tires as theres a unique flaw, sometimes you can move them from corner to corner to fix it. (Super rare) usually pulls to one side a bit not shakes.
Check tie rod ends, check new rotors for factory warpage..
Also, if you did not clean the rotors the wax coating left on to avoid rusting on the shelves may cuase wierd gripping/sliding effect till it burns off..
Goodluck
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 09-28-2014, 08:34 PM
BMW_Stu BMW_Stu is offline
Mein Auto: Camaro, soon to have BMW
I have noticed mine does this as well. I notice it if i'm creeping while on the brakes, less than 1mph. I don't feel it in normal braking, or when coming to a stop, only at creep speeds. Did you ever figure this issue out?
Old 09-29-2014, 09:33 AM
I did get it resolved. I don't know why I did not consider this earlier- rear brakes. I rebuilt the rear brakes , new rotors and pads. Problem solved.
The car now comes to a stop ever so smoothly. There was plenty of life left on the old pads, the rotors looked good but maybe they were somewhat warped.
That's why I didn't consider it, visually it looked like i had a least another 10-15k left on them. I guess I was wrong, but I was pleasantly surprised when that fixed it.
Moral of the story- sometime the fix is right in front of your face.
Rob T
Current toys...
Old 10-08-2014, 10:18 AM
MeNoo's Avatar
MeNoo MeNoo is offline
Smuggled into the 'Fest
Mein Auto: 1990 BMW E34 525i
That's why they told you to check runout....
HELGA-90' 525i
Unnamed-98' 328i
