E34 (1989 - 1995)
Old 08-11-2014, 02:26 AM
Trickyricky83 Trickyricky83 is offline
Mein Auto: 1990 BMW 525i E34
Need help and advice for 1990 E34 525i
Can someone please give me sone advice. I just replaced the clutch in my E34 and now after install of new clutch and bleeding if the hydraulic pump for it, it STILL WONT CHANGE gears please help with any advice possible I'm tired of paying these so called expert mechanics and their BS. I need my baby back on the road!!!
Old 08-11-2014, 10:16 PM
TexHun TexHun is offline
Every Ricers Nemesis
Mein Auto: 87 528e, 94 540i/6
Your master cylinder could be out. You have the slave cylinder at the tranny and the master cylinder on the pedal at the firewall. If you have a new clutch and slave cylinder then the master cylinder is your only other culprit, if not then you have major tranny issues, unless the "EXPERTS" didnt put the shifter assembly back properly.
If it ain't broke, FIX IT!!
99 328is Avus blue sold
87 528e with 455k miles and still running hard from death
94 540i swapped to 6 speed awesomeness
Most of what you need to know for a manual conversion
http://www.bimmerfest.com/forums/sho...d.php?t=768139
Old 08-12-2014, 02:44 AM
I please no don't let it be the tranny... would the clutch going out blow the tranny? Cuz before that clutch went out tranny was fine no issues at all and as far as the assembly goes idk that's why I paid them cuz they supposedly knew what the hell they were doing
Old 08-12-2014, 02:47 AM
The hydraulic clutch part I believe is just fine as well because of the bleeding procedures. Cuz it's first the master then the slave and that all went accordingly To my knowledge... As I used Jessie bible to the e34 n a website that tells you things any manual doesn't
Old 08-12-2014, 08:14 AM
BMWFatherFigure's Avatar
Old School
Get under and watch the clutch slave while some one works the pedal. Does it move correctly? Does it allow easy selection of 1st? If first is an easy select with the engine running then it is not the clutch or its installation. Look elsewhere.
Current:
E38 Parts Car
Previous:
Old 08-12-2014, 08:16 AM
Cool thank you I appreciate the info!!
