Opinions on muffler and resonator delete? - Bimmerfest - BMW Forums
Old 08-11-2014, 10:53 PM
kuurdii kuurdii is offline
Mein Auto: 2006 325xi
Should i get my resonator and muffler deleted? is it a good idea to do so?
also, does it cause any problems/
Old 08-12-2014, 01:50 PM
riviera1969 riviera1969 is offline
VELOZV
Mein Auto: 2008 BMW 335I STICK SHIFT
Muffler delete
I took mine off and cost me $60 aslo no problems. I did the same with teh E46 I had.
This is what it sounds like cold and on the street.
Old 08-12-2014, 01:54 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Removing doesn't sound too bad. The Fiat Abarth comes this way from the factory and I think it sounds great for a 4 cyl FWD. It sounds pretty good in this vid above too.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 08-12-2014, 02:39 PM
so should i get both my muffler and resonator deleted together?
Old 08-12-2014, 03:24 PM
Mein Auto: '06 AW 330xi
Ehh, I'd rather put a universal magnaflow muffler and delete the secondaries and resonator.
Muffler deletes are too raspy for me
Old 08-12-2014, 03:27 PM
can you give me a link for a good Magnaflow muffler?
