E90 2005 Angel eyes? - Bimmerfest - BMW Forums
Old 08-12-2014, 12:24 AM
Phasio Phasio is offline
Mein Auto: 320d E90 2005
Hi all,
I spent quite a lot of time researching how to get angel eyes in my 320d from 2005 (E90) and I'm simply not sure exactly what to do. I asked a BMW dealer who claimed that it'd never be the same as the headlight in the new models (quite an annoying answer, as that wasn't the question!).
Since it's a 05' car, I'm quite sure that's it's not LCI -> thus, I'm not sure if I should replace the entire headlight, or if it's possible at all to just replace the 'bulb', or is that a poor solution?
Any help would be greatly appreciated.
Old 08-12-2014, 06:14 AM
Mein Auto: '06 AW 330xi
Post a picture of your headlights.
If you have halogen for that model year, you need new housings.
Old 08-12-2014, 08:29 AM
Thanks for the quick response :-)
This is my car
Old 08-12-2014, 08:52 AM
bad karma bad karma is offline
Mein Auto: 2011 335i M-Sport E90 SBM
You will need to replace the entire headlight assembly with a third party solution to get proper projector lense housings with HID bulbs/ballasts and the Angel Eye rings.
Old 08-12-2014, 08:54 AM
Yea you have to replace the entire housing.
Check out DEPO housings.
User fishcake321 on eBay sells pre-modded sets with upgraded angel eye rings.
Old 08-12-2014, 11:10 AM
mike@x-ph.com mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Unfortunately no easy fix in your case
You need to replace the entire housing.
2005, 320d, angel eye, e90
